Bmw E30 318i Idle Problem. Help!!! - BMW Forum - BimmerWerkz.com
Old 06-02-2005, 06:26 AM   #1 (permalink)
Privateye is an unknown quantity at this point
I have a 87-88 BMW E30 318i. Recently, i have started to experience an idling problem. When i start the car for the first time the idle sits on 1000rpm and then gradually starts dropping until the car turns off. The only way to prevent this is for me to keep my foot on the pedal. After the car has warmed up, it starts to idle properly. This problem occurs everytime i cold start the vehicle. Any ideas on what could be causing this?
Thanks in advance
Privateye is offline   Reply With Quote
Old 06-02-2005, 01:00 PM   #2 (permalink)
If you’ve got a M10 then it could be the auxiliary air slide valve or you’ve got an air laek in the inlet tracked somewhere
Old 06-02-2005, 05:08 PM   #3 (permalink)
Where is the auxiliary air slide valve located? Also where are the vacum pipes located?
NEW MATCHING SHIFT & E-BRAKE BOOT SET BMW E30 318 325 customshiftboot Aftermarket Parts 0 09-13-2005 10:59 PM
Help!! Urgent Idle Problem BMW328 3-Series (E36) 6 06-27-2005 12:07 PM
Idle Problem 93 325i 3-Series (E36) 21 12-07-2004 09:42 AM
