Blower Resistor & A/C - BMW Forum - BimmerWerkz.com
Old 06-18-2010, 03:43 PM   #1 (permalink)
86Black325e is on a distinguished road
Exclamation Blower Resistor & A/C
I believe I have two separate problems here, so my main question really is if anyone knows if the two could somehow be linked.
First off some brief history since I'm a 'n00b':
I got my 325e in August 2009 for $2250 (now has 137,000 mi).
I've done some decent work on it already over the past year with the extensive ones being:
- In winter, replaced control arms/ball joints, sway bar links, and sway bar brackets.
- In early spring, alternator.
- Last weekend, starter (insane job, about 10-12 hrs).
Back to the blower/ac...
I noticed the AC didn't blow cold not long after I bought it last August. So, I figured at some point I would need to check out the AC. Then not long after I noticed the AC wasn't blowing cold air, the vent was only working when the vent dial was turned to "4". This is because of a faulty or dirty blower resistor. SOOOO....my question is: When I replace the resistor, is it possible my AC will blow cold air again??
I assume not, but when I have the ignition set to '1' so that the battery is turned on and I push the AC button, it lights up blue and I can hear the receiver dryer and fan turn on. I may need to recharge r12...........?
I APPRECIATE ANY ASSISTANCE!!
- PAUL
86Black325e is offline   Reply With Quote
Old 06-18-2010, 04:04 PM   #2 (permalink)
Likely it needs new refrigerant, but leaks need to be hunted and fixed first.
Old 06-18-2010, 04:05 PM   #3 (permalink)
The theory behind leaks?
Old 06-18-2010, 04:08 PM   #4 (permalink)
Most likely, leaks allowed the refrigerant to escape.
Old 06-18-2010, 04:10 PM   #5 (permalink)
Right, ok.
I'm very apprehensive to convert to r134.
What is the best overall route (besides suffering in summertime heat) do you think?
Old 06-18-2010, 07:18 PM   #6 (permalink)
If at all possible, try to use the new type of refrigerant.
Old 06-23-2010, 09:33 PM   #7 (permalink)
the real problem here is that
you have a crapped out 30 year old A/C unit in a BMW that really wasn't worth shit to begin with...that's the problem...you will never be able to fix this to your satisfaction..believe me....best of luck
silversled is offline   Reply With Quote
Old 06-28-2010, 03:57 PM   #8 (permalink)
Well I'll have to either get my hands on some R12 or re-convert it to R134. I'm not keen on vacuuming it. If you go that route, you'll be due for leaks soon enough.
Need info on changing blower resistor!! bucketyed 3-Series (E46, E90) 3 01-14-2012 11:35 AM
HELP PLEASE!!! Could it be my blower resistor???? ONE ILL740 1,6,7,8 - Series and Mini Cooper 8 07-02-2009 06:32 PM
Blower motor resistor location ssm318ti 3-Series (E36) 3 02-09-2009 07:03 AM
Blower Motor Resistor Removal wulley1 3-Series (E36) 4 12-30-2004 06:36 PM
blower sword or resistor sanga 5-Series (E12,E28, E34, E39, E60) 4 09-10-2004 06:59 PM
