vacuum applied works wayy better than pressure
if you have a simple vacuum hand pump find a way to seal off the top of the brake fluid reservoir and run the vacuum line into it...pump it up vacuum pressure to about 15-20 psi and watch the bubbles come up, does all the work for you...
this only works with the clutch, not the brakes
