Big Oil Leak - BMW Forum - BimmerWerkz.com
Old 12-29-2005, 08:27 PM   #1 (permalink)
JoeMadoo's Avatar
JoeMadoo is on a distinguished road
Send a message via AIM to JoeMadoo Send a message via MSN to JoeMadoo Send a message via Yahoo to JoeMadoo
Big Oil Leak
Hello... My bimmer has a massive leak between the Engine and Tranny. I believe thats the rear main seal? How hard is it to replace that or whatever seal/gasket it may be?
86 Alpine White 335is M30 Swap <br>My Car Domain
ASE L1 Smog Certified
JoeMadoo is offline   Reply With Quote
Old 01-02-2006, 08:08 AM   #2 (permalink)
It’ll be either the rear crank main or the gearbox in put seal if it’s an auto then that can be a big leak, if so look at the colure of the oil ATF is red. A rear crank main oil seals isn’t hard to change if once you’ve got he box out then unbolt the flywheel and it’s in front of you.
Old 01-04-2006, 10:49 PM   #3 (permalink)
Car: Opening soon:
The oil pan will also leak in this area as well. Too bad you can't tell unless you pull the trans.
Oil Leak From Bottom Of Engine??? BIG 730 1,6,7,8 - Series and Mini Cooper 3 12-19-2005 02:57 PM
Oil leak... Regnout 3-Series (E36) 21 11-07-2004 09:06 PM
