Bent Alternator Bracket? - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 04-21-2005, 10:42 AM Thread Starter
jk988 is an unknown quantity at this point
OK, I searched this and I could not find any info.
On my 325e, the alternator bracket appears to have bent. When looking down at the alternator, it is slanted so the pulley side leans toward the engine. The drive belt is still on the pulley, but it looks like it could fall off or break at any moment. The drive belts were replaced a couple of years ago, about 10k miles. Obviously, this is not a good thing. I have stopped driving it until I can get it diagnosed.
Any ideas?
jk988 is offline
post #2 of 4 (permalink) Old 04-21-2005, 11:27 AM
Pandemonium Director
nukeduster's Avatar
nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute
Any ideas?
[snapback]335967[/snapback]
hopefully its only the adjuster bracket thats bent
if it is just do a search for p/n "12 31 1 274 833"
that should fix her up.
nukeduster is offline
post #3 of 4 (permalink) Old 04-21-2005, 11:52 AM
Id have a look at the rubber bush that mount the bottom of the alternator I used to change loads on M10 engine so the M20 is much different they go soft and the alternator leans in towards the engine, you can but the bushes separately a bit of a pain to fit clean the recesses well and use a vice and socket to press them in..
bad man working is offline
post #4 of 4 (permalink) Old 04-22-2005, 05:14 AM
draculia is an unknown quantity at this point
if its a rebuilt alt there are no bushings.
the adjustment bar is weak and sometimes breaks. if its not broken you could remove it and bend it back. if it is broken they are cheap money. the bushings are also cheap money if you do have them.
draculia is offline
Where To Fix A Bent Rim? ErikB 5-Series (E12,E28, E34, E39, E60) 0 07-02-2005 06:38 PM
Have 3 Bent Rims emr0591 3-Series (E46, E90) 1 11-15-2004 12:59 PM
Bent Drive Shaft Bimmer///Man3 3-Series (E36) 3 08-28-2004 02:17 AM
Bent shift fork?? Stuka 5-Series (E12,E28, E34, E39, E60) 8 03-19-2004 04:31 PM
Mis-shifted, bent valve? Armaan 3-Series (E46, E90) 5 08-15-2003 08:13 PM
