I'm looking at getting BBS RX 17x8 with 10 offset wheels. I will be installing Eibach Pro Kit with Koni Adjustables. Will these wheels fit my lowered E30. Also what is the widest tire I can fit on these wheels that will not rub on my fenders.
that will deffinately give you a wider track, but it might cross the line from aggresive to goofy looking. you run a risk of damaging your fenders no matter what tires you put on, unless you roll your fenders; due to such a low offset. a 8" wide wheel would be better suited with something around a 15mm offset on your car. if you had a friendlier offset and rolled fenders you could probably squeeze 245's in the rear, but i think the most you'll be able to fit is 225's (if you can find the proper sidewall profile) and that is a very good amount of rubber for a e30.
8" ET10 would be about an inch into your fender's space.
With the right offset (20-25), 225 width is the widest going into stock 88+ fenders. But if you have an 8" wide wheel, 225 wouldn't work. You'd have to go with a 215.
after looking at tire sizes, it looks like 215/40/17 is going to be your only option as far as tire sizes go.
i really think anything higher than a 20mm offset will come dangerously close to rubbing the strut once the tires are mounted, and anything under 15mm will not have adequate fender clearance. when running a 8" wheel on a e30 there is very little tolerance concerning offset, imo i would keep looking for a wheel no wider than 7.5" wide. also, with a 15" or 16" wheel, you can find tires in 225 that will fit.
Any 7.5" wheel with a ET25 offset is the ringer setup. That or VERY close (meaning 23-27) will fit a 225. Otherwise, a 7.5" with 20-30 will work with a 205. Also, 225/45/16 and 205/50/16 are the sizes I'm talking about.
The bolt pattern is 4x100 and the hub needed is 57.1mm.
Originally posted by Mystikal@Jul 14 2004, 04:31 PM Any 7.5" wheel with a ET25 offset is the ringer setup. That or VERY close (meaning 23-27) will fit a 225. Otherwise, a 7.5" with 20-30 will work with a 205. Also, 225/45/16 and 205/50/16 are the sizes I'm talking about.
Hi Mystikal, I PM'd you a few days ago. Did you receive my message?
on a stock size rim what is the widest tire that I could fit on my car? Ok, stock height rim. I think its like what, a 14"? 15"? Do you think I could fit a 205? 215? @_@ I'm so bland in tire talk, but I want wider tires for more grip. I'm planning to get the fender flares off ebay or something so it'll look right, but if you have any suggustions, that'd be tight.
Originally posted by Halon@Jul 15 2004, 11:01 PM on a stock size rim what is the widest tire that I could fit on my car? Ok, stock height rim. I think its like what, a 14"? 15"? Do you think I could fit a 205? 215? @_@ I'm so bland in tire talk, but I want wider tires for more grip. I'm planning to get the fender flares off ebay or something so it'll look right, but if you have any suggustions, that'd be tight.
i think the widest tire you can find for a stock 14" rim would be 205
For mainstream tires, the best bet is 205/60/14 Yoko ES100's. You can get 225-width rubber, but it's only track stuff. Also take a look at the Falken Azenis Sport. It comes in a 195/60/14 size, but it'll grip better than any other 14" road tire you can find.
Also don't worry about fender work, you wouldn't even notice a difference visually.
