Battery Not Charging - BMW Forum - BimmerWerkz.com
Old 12-19-2004, 05:28 PM   #1 (permalink)
woode12 is an unknown quantity at this point
On my 1989 325 I put in a new alternator and battery. The car will run for a wile then die. When I test the system I only getting 12.4 volts. I cleaned all the wires. The light on the dash comes on when you start the car then will go off. When I drive I can drive for about 30 min. then the car will die. Why an I only getting 12.4 volts out put from the alternator?
woode12 is offline   Reply With Quote
Old 12-19-2004, 07:13 PM   #2 (permalink)
Speedy-325is's Avatar
maybe you hooked it up wrong....
take it off and have it tested.
have the battery tested also.
maybe you got a bunk alt. it happens, was it a remanufactured alt or brand new? what brand?
Old 12-19-2004, 07:18 PM   #3 (permalink)
[snapback]254420[/snapback]
New on. It hooked up right. What volts is it sopost to be?
Old 12-19-2004, 08:34 PM   #4 (permalink)
13.5 volts on a fully charged battery and 14.25 on a battery getting maximum charging possible.
The issue is the alternator or the way it is connected.
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
battery lost charge..proper way to charging it wcre34 3-Series (E36) 8 09-07-2005 09:21 PM
Help - Battery Light Is On (again) Pegasus 3-Series (E36) 6 10-01-2004 11:14 AM
battery & Blue Lights pk_usf 3-Series (E46, E90) 0 10-20-2003 02:09 PM
