No alarms other than the ABS light coming on after starting. What I'm looking for is whether I need to do step by step pulling of fuses, using a voltmeter, etc.
Disconnect the negative battery lead from the battery. Take a ammeter (I use a multi meter) and hook it up between the negative battery cable clamp and the negative battery post. If you see mre than about 200ma, start removing and replacing fuses (one at a time) until the current draw drops and you now have located the offending system. I would continue the drill using all fuses to be sure there is not more than one system over drawing current.
check the fuses with ... fuk i 4got wat its called...it has a lgith in side of it and looks liek a screwdriver with a really pointy tip and it has a ground wire comming off it...hmm ill try and get the name of the tool
^^I want this where I live.
"Drag racing a BMW is like going fishing with a hooker, it's fun but it's not what you got her for..." - M3DUDE
Manual - The transmission hated by moms/wives/girlfriends everywhere...
Member of the "I Owned my Bimmer when I was 17" Club
Member of the "10 Year Old" Club
Member of the "3 Pedal" Club
Member of the "3 Light" Club
Originally posted by Slvr E30iS@Aug 26 2004, 05:03 PM check the fuses with ... fuk i 4got wat its called...it has a lgith in side of it and looks liek a screwdriver with a really pointy tip and it has a ground wire comming off it...hmm ill try and get the name of the tool
um you pull the fuse and look at it...you can tell if its blown HOMESLICE lol and its an Ohm meter BTW i doubt fuses have anything to do with this but its worth a shot
__________________ Kyle Sutherland
1995 BMW 540i/6: The Calypso Beast Vid 0-70ish 1987 BMW 325es: Face & Butt Lifted/M50tu Swapped*Sold* 1985 VW Scirocco: Too many mods, money pit*Sold* E34 Plate Filler Wanted!
Originally posted by Carbarns@Aug 26 2004, 05:19 PM Yes, the fuses themselves are fine. It's the systems the fuse serves is the problem.
I'm really looking for the next steps to isolate the exact device causing the drain (fan, light, tach,...)
yup thats the next step i would go for
