Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 05-02-2004, 07:29 PM   #1 (permalink)
tyro2001's Avatar
Photos: 0
tyro2001 is an unknown quantity at this point
about 2 month ago my car battery died out, so i changed it and today after not starting it in a few days it died? why does it keep dieing or getting wasted. the only thing that i see that stays on when i turn off the car is the time on the dashboard next to the CD, but i dont think that little LCD thingy will kill a car battery any ideas.
thanks alot
tyro2001 is offline   Reply With Quote
Old 05-02-2004, 09:59 PM   #2 (permalink)
Photos: 0
If the battery is not a suspect, I would get the charging system checked.
Usually it is a regulator brush assembly that needs changed.
Alternator Regulator
Here is a picture of the old and a new part.
They can wear into a grooved pattern and the impact of driving can make them vibrate out of the normal groove.
Since the regulator has to increase output to jump the gap it does.
You can clean up the slider rings with abrasive paper.
You can get the brushes as a separate part requiring soldering skills or you can get a Regulator brush assembly for $70.
Some instruction for changing:
It is a very touchy installation and about 5% of the installation end in the ground link bent and the alternator not functional.
You can remove correct and reinstall the regulator.
The output must be 14.25 or higher on a Volt Ohm Meter not the dash gauge.
Some hints on the regulator change.
Replacing Alternator Regulator
For those who work on their cars and have not had alternator problems, here is a simple action that should save you down-time and significant costs.
Most alternators on German cars fail due to brushes wearing down (as they are supposed to) between 150k and 200K miles. Brush replacement is very easy -- it should not take over 20 min. and the brushes are attached to a new regulator.
To replace regulator assembly -- back of alternator held in place with two straight slot headed screws. This has a round transistor mounted on the outside on Bosch alternators -- the other type is similar but uses different brushes. Pop the regulator out, after removing the screws.
Fitting the regulator back is simple, but you must install it starting at an angle, to assure that the brushes compress when the regulator is flush with the alternator and the screws are tightened.
You are now ready for 200K miles of alternator life.
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
Old 05-02-2004, 10:50 PM   #3 (permalink)
tyro2001's Avatar
Photos: 0
i cheaked the Alternator by taking the positive wire of the battey as the car was running and the car didnt turn off.
does that mean the Alternator is good. or just of waste of time
Old 05-07-2004, 06:21 PM   #4 (permalink)
Photos: 0
jtorres is an unknown quantity at this point
Send a message via AIM to jtorres
check your fuses for burned out ones.
jtorres is offline   Reply With Quote
vB code is On
318i-Not charging Hypnogaja 3-Series (E21, E30) 15 10-27-2004 04:18 PM
Help - Battery Light Is On (again) Pegasus 3-Series (E36) 6 10-01-2004 12:14 PM
battery & Blue Lights pk_usf 3-Series (E46, E90) 0 10-20-2003 03:09 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
