Bad Clutch? - BMW Forum - BimmerWerkz.com
Old 05-27-2004, 11:06 PM   #1 (permalink)
1980 BMW 323is is an unknown quantity at this point
Send a message via AIM to 1980 BMW 323is Send a message via Yahoo to 1980 BMW 323is
I was driving my bimmer one day when something went wrong while shifting from 1st to 2nd. It made a some kind of stripping noise like it wont go into gear. When driving normally it doesnt do it much, but when redlining 1st gear, it happens during shifting into 2nd gear.
1980 BMW 323is is offline   Reply With Quote
Old 05-28-2004, 01:31 AM   #2 (permalink)
A|peX is an unknown quantity at this point
hmmm, well I think I know what you mean. Sorry I don't know the answer, but when I was shifting from first into second I think my bimmer made that noise you're talking about. But this only happened a couple of times (I think it happens ***for me *** because I shifted into second too fast).
Also, my shifter kinda vibrated it was like VVVRRRRR kinda noise.
btw i have 1984 325e. Sorry, not much help i guess....
A|peX is offline   Reply With Quote
Old 05-28-2004, 07:26 AM   #3 (permalink)
CiscoKid's Avatar
make sureyou are pressing the clutch in ALL THE WAY
Old 05-28-2004, 10:56 AM   #4 (permalink)
Halon is an unknown quantity at this point
Send a message via AIM to Halon Send a message via MSN to Halon Send a message via Yahoo to Halon
it sounds to me like your syncros may not be good. I'm not a good mechanic or anything, but I know that the grinding you hear when you mess up a shift alot of the time is the "dog teeth" trying to mesh the gear with the well whatever the gear meshes up to. haha, another wheel of some sort. hmmm, you can tell I'm not good at this. I estimate it being your bad syncros, I had to drive a car with bad syncros between second and third for a while. Third had a pop-out-issue or something, when you shift into gears that it grinds like that, hold the shift in gear really firm with your hand and see if it happens smoothly like that, thats what i had to do in the fox. haha. Hope this helps, or gets you on the right track.
Halon is offline   Reply With Quote
Old 05-31-2004, 09:33 PM   #5 (permalink)
Cisco kid, i'm not some kind of stupid driver okay. I do press the clutch all the way down, thanks for the tips guys
Old 06-01-2004, 01:05 AM   #6 (permalink)
Damn I just thought of something else it could be, but it slipped out of my head... Oh, check your car. Turn it on, and then when you start it, turn off all your radio and fan, ac, all that shit. Press the clutch in, if you can hear a high pitched sort of a whine, it may be a bad clutch assembly. The whine from what I have heard is the sound of a throw out bearing going bad. So you may try that, I know thats one of the things I hear when I do it. So I am planning to replace my clutch. Also, does anyone know if the 1985 318i had solid lifters? I'm beginning to wonder, because if not, it sounds like I may have a bad valve or something. I'm trying to figure that out before it becomes bad. But if we have solid lifters then that might explain some of the noise. I may just be paranoid. Oh well. Thanks.
Old 06-02-2004, 10:33 PM   #7 (permalink)
Kevin325i's Avatar
I second the syncro theory. It's likely your engine is spinning to fast to go into second without the rpms dropping a little.
Has the car always done this? Does it do it during downshifts?
Kevin
Kevin (President TBEA)
Old 06-03-2004, 12:39 AM   #8 (permalink)
It shifts well in every other gear except from 1st to 2nd. And it only does it once in a while
Old 06-03-2004, 09:13 PM   #9 (permalink)
Kevin325i's Avatar
Sounds like a syncro to me.
Kevin
E34 Clutch Switch -- HELP ! ! ! m3driver97 5-Series (E12,E28, E34, E39, E60) 5 10-28-2005 05:22 PM
Clutch Kevin325i 3-Series (E36) 13 08-06-2004 12:09 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
E36 M3 UUC Flywheel Wrong Clutch Becherert 3-Series (E36) 1 03-09-2004 01:39 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
