| There is no switch for it. The aux. fan comes on 2 ways, coolant sensor sees the engine hotter than it should and turns it on, or when you turn on your A/C the aux. fan will come on. If you really wanted to be able to switch it on whenever you wanted I'm sure with the proper wireing diagram you can find the right wires to tap into. |
