Anyone Know How To Change Obc - BMW Forum - BimmerWerkz.com
Old 03-14-2005, 11:59 AM   #1 (permalink)
guywithblack88e30's Avatar
guywithblack88e30 is an unknown quantity at this point
Unhappy
anyone know a easy way to change 6 button to 9 button obc??? any diy's? or any experiences???
Member of got its raining(in Members Lounge) to 100, 237, 250, & 300 pages club...
Member of 3 Pedel club...
Member of ran away from cop using DRIFTING not speed(ok a little speed)...
guywithblack88e30 is offline   Reply With Quote
Old 03-14-2005, 12:21 PM   #2 (permalink)
CiscoKid's Avatar
i think that the cabels are differnet
Old 03-15-2005, 12:05 AM   #3 (permalink)
i heard there was a way to do it thou
Old 03-15-2005, 11:19 PM   #4 (permalink)
fporro is an unknown quantity at this point
Send a message via MSN to fporro Send a message via Yahoo to fporro
[snapback]311677[/snapback]
is not difficuly at all. easy afternoon job.
you'll have to remove the gauge cluster and pull forwad the heater/radio panel,
also an obc compatible wire harness and the obc control module to activate engine disable funtion "code" from obc., if you feel like it, then add a compatible turn light switch so you can toggle obc functions from it.
my E30 store
cheers,
Frank
e30 parts
fporro is offline   Reply With Quote
Old 03-15-2005, 11:50 PM   #5 (permalink)
i got the obc from the junk yard but i wanna know what else i need. pics if you got them and pics of the process if you got those to
Old 03-16-2005, 07:11 PM   #6 (permalink)
schneider252's Avatar
Originally posted by fporro+Mar 15 2005, 11:19 PM--><div class='quotetop'>QUOTE(fporro @ Mar 15 2005, 11:19 PM)</div><div class='quotemain'><!--QuoteBegin-guywithblack88e30@Mar 15 2005, 12:05 AM
my E30 store
[snapback]312467[/snapback]
[/b][/quote]
little pricy there eh...
Old 03-17-2005, 12:35 AM   #7 (permalink)
give you a hint,
almost 100 miles round trip, time and gas, time to remove them, cost of parts, cost of listing them, final value fees, paypal fees. time answering questions, packing them, 20 mile round trip to post office, etc.
i'll be lucky to brake even on most parts. ghead
cheers,
Frank
e30 parts
Old 03-17-2005, 01:14 AM   #8 (permalink)
well what obc wire do i need i don't mind trip 2 junkyard
Member of got its raining(in Members Lounge) to 100, 237, 250, &amp; 300 pages club...
Old 03-17-2005, 02:02 AM   #9 (permalink)
[snapback]313295[/snapback]
yes, you'll need that wire harness, there's a second harness that runs through the firewall, yu already have the temperature sensor so unless you want the second horn then don't bother.
main obc harness will have 7 or 10 plugs, depending on the year.
2 connectors run towrads ecu in glove box, also there's one that goes behind gauge cluster.,.
remove left most screw from abs ecu so you can get harness out from below. pull airducts out of the way.
also the black box, see my ebay item # 7947353953
or this pic ...
cheers,
Frank
e30 parts
Brake rotors a must change?? Z0Sicks 3-Series (E46, E90) 3 11-06-2005 01:23 PM
timing belt change and mechanics in miami träumer 3-Series (E21, E30) 6 10-03-2005 03:44 PM
The Green Lights For Oil Change Henri 3-Series (E36) 13 10-23-2004 09:49 AM
When to change "lifetime" tranny fluid LloydM 3-Series (E36) 9 08-31-2004 03:38 PM
Oil Change brosnan6 3-Series (E36) 2 12-23-2003 06:36 AM
