Any Difference? - BMW Forum - BimmerWerkz.com
post #1 of 13 (permalink) Old 11-29-2004, 10:33 PM Thread Starter
Halfnhalf325 is an unknown quantity at this point
I was just wondering what the diference between the intakes on Ebay are compared to something like the BMP intake.
Halfnhalf325 is offline
post #2 of 13 (permalink) Old 11-30-2004, 12:06 AM
pettas is an unknown quantity at this point
I was wondering this as well. BMP Designs High Flow Racing Intak seams more thought out and well created, but I don't know if it would have any benefits over a EBAY one.
I myself am in love with BMP Design, so Id rather spend the 120 dollars at BMP vs the 20 on ebay, even if they gave the same performance. Im a junky for BMP hehe =)
-Andre
pettas is offline
post #3 of 13 (permalink) Old 11-30-2004, 02:42 AM
guywithblack88e30's Avatar
guywithblack88e30 is an unknown quantity at this point
intakes dont make a difference on our cars even with heat shield ur best bet is to go get a k & n and keep the air box intakes give us nothing but sound i've tried it and i went back to k&n with stock air box
Member of got its raining(in Members Lounge) to 100, 237, 250, & 300 pages club...
Member of 3 Pedel club...
Member of ran away from cop using DRIFTING not speed(ok a little speed)...
guywithblack88e30 is offline
post #4 of 13 (permalink) Old 12-02-2004, 11:28 AM
Bimmin'88's Avatar
Bimmin'88 is an unknown quantity at this point
Stock air box w/K&N. Custom CAI!!
K&N cone filters rated @ 8-900 cfm
K&N flat filters rated @ 450 cfm
What I did ensures constant cold air plus at speeds over 70mph = 1+ psi ram into the intake.
Lots of diff opinions on what works best.....I like my setup seems to work just fine.
$45.00 for the filter.
$15.00 for the CAI parts (Home Depot).
Member: "Ran from a cop and got away" Club
Member: "Old Guys Rule" Club
Bimmin'88 is offline
post #5 of 13 (permalink) Old 12-02-2004, 02:40 PM
like the emblem on it nice
post #6 of 13 (permalink) Old 12-02-2004, 02:45 PM
i was thinkin of doing a cold air intake on my car running it done right next to the front valence nest to the fog light (sorry to use ur pic bimmin)
post #7 of 13 (permalink) Old 12-02-2004, 05:27 PM
Official Bimmerwerkz Biscuit Distributer
spiff325is's Avatar
spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of
Send a message via AIM to spiff325is
bmp's heat shield is a joke, btw.
I hate: people who haven't died yet that I hate.
L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc.
2000 BMW M Coupe - Dakar-II - S52
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
spiff325is is offline
post #8 of 13 (permalink) Old 12-03-2004, 12:14 PM
Bimmin'88's Avatar
[snapback]242114[/snapback]
Keep the intake away from the tarmack...road surface temps can get up to 140? but this will depend on where you live and sesonal changes.
Plus going through the high beam was WAY TOO EASY...and the air flow is direct with very slight bending of the tubing. Almost a straight shot into the Air Box.
Those brake cooling ducts on the valence can be made more effective by replacing the stock tubes with some flexible hose and directing the air flow to blow at the base of the rotors. This is a future project for me. I'll post when completed.
post #9 of 13 (permalink) Old 12-03-2004, 04:44 PM
emericadna7 is an unknown quantity at this point
Send a message via AIM to emericadna7
bimmin, did you notice a differnce in power when you put the in take there? and did you just cut the high beam away? i would like to know how you did it if you could
emericadna7 is offline
post #10 of 13 (permalink) Old 12-03-2004, 05:34 PM
87 325iS is an unknown quantity at this point
There is no power, it's a waste of time. You would have to go WELL over 100 MPH to even gain a fraction of a psi. Also, I wouldn't reccomend making your "CAI" down by your foglight, unless of course you want to hydrolock your engine.
Amberfire 2000 Dodge Dakota R/T
Rusted, fallling apart Alpine White 1987 325iS - Gone but not forgotten
<img src='http://img.photobucket.com/albums/v255/HeilSova/Sig.jpg' border='0' alt='user posted image' />
87 325iS is offline
post #11 of 13 (permalink) Old 12-03-2004, 07:37 PM
Bimmin'88's Avatar
[snapback]242979[/snapback]
Have to disagree with "well over 100"...@ 70mph the psi is at 1 and will climb from there...not much...but you will get increased / rammed air into the intake. And at speeds above 70 I do feel the diference.
As far as HP gains....its not much at all....the biggest restriction is the AFM. Up grade to Big Six AFM and you WILL feel the HP.
On my car I just removed the HiBeam bulb. And went to the Home Depot.
Plumbing Section:
1- 3" to 4" flexible reducer
1- short piece of 4" ABS pipe (I found some straight fitting Piece ..sorry don't remember what to call it)
1 Sqare Foot of 1/4" x 1/4" wire mesh (at the garden center)
1- lenght of 3" flexible ducting (Heating and AC section)
You should be able to figure it out from here...if not let me know and I will post some pics and better instructions.
It is really easy and nothing is bolted or strapped in!!
Member: &quot;Ran from a cop and got away&quot; Club
Member: &quot;Old Guys Rule&quot; Club
post #12 of 13 (permalink) Old 12-03-2004, 08:10 PM
Bimmin'88's Avatar
some brain candy
http://www.bmwe30.net/cgi-bin/datacgi/data...0004&Section=03
post #13 of 13 (permalink) Old 12-03-2004, 09:08 PM
sexydylan05's Avatar
sexydylan05 is an unknown quantity at this point
Send a message via AIM to sexydylan05
[snapback]242010[/snapback]
hey what did you do for you car what kind of inatke did you do and can you explain it to me sexydylan05
sexydylan05 is offline
X-brace makes a difference Live_the_Curves 3-Series (E36) 7 10-01-2005 01:55 AM
Whats the difference ? ste328 M-Series (M1, M3, M5, M6) 3 07-11-2004 09:44 PM
difference between pre 97 540i engine and post. oraph 5-Series (E12,E28, E34, E39, E60) 0 05-19-2004 06:22 PM
difference in early 92 E36 front suspension miatawnt2b 3-Series (E36) 19 03-25-2004 09:58 AM
What's the difference? cardio Other Rides 7 12-13-2003 09:01 AM
