| if the light comes on it means either, as badmanworking said, the sensor / wiring is damaged, or the abs system is not functioning.
brakes will still work, just the pulsing the abs systems do will not function and the brakes will lock under hard braking.
__________________ When you fight, you don't fight for abstract values like the flag, or the nation, or democracy. You fight for your buddy. You fight to keep him alive, and he fights to keep you alive, and you go on that way, day after day, battle after battle. And when one of your buddies dies, something inside you dies as well. But you go on. You fight, so that his death isn't meaningless, his sacrifice isn't for nothing.
-Dick Marcinko |
