Alternator One Last Time - BMW Forum - BimmerWerkz.com
Old 03-30-2006, 07:44 AM   #1 (permalink)
1990 325ic. What is the best way to get at the pivot bolt on the alternator (the one above the PS Pump). Should I remove the air box and plenum and go in over the top with a ratchet, short extension, and socket. Or, should I go in from beneath by unbolting the PS pump and setting it out of the way?
All suggestions greatfully accepted.
Old 03-30-2006, 10:15 AM   #2 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
When I replaced my alternator I took out the air box....not sure if that's the easiest way, but that's how I did it. I've actually taken the air box out a few times--it's a pretty easy task..
yammahamma is offline   Reply With Quote
Old 03-30-2006, 10:34 AM   #3 (permalink)
Alternator Again
Works for me, Thanks.
Old 03-30-2006, 01:40 PM   #4 (permalink)
yammahamma's Avatar
Car: '01 330i
I should also say that when I replaced my timing belt I had to go at it from underneith (spell check) and it was a much bigger pain to take off those plastic undercarrage/wheel well covers then it is to take out the air box. and if you don't have lift then I would FOR SURE go in from the top.
Old 03-31-2006, 02:32 PM   #5 (permalink)
Alternator one more time
Thanks for the help, I took the MAF and air box out, tightend the alternator pulley belt and put her back together in about 30 minutes[/SIZE].
Aight RICHMOND... meet time.. CCMW included...!!!! 97alpineM3 South East 4 12-07-2005 09:27 PM
At this time id like to thank... Furious Bimmerwerkz.com Site Help 1 10-03-2005 10:43 PM
Time For An Update Kevin325i 3-Series (E36) 13 04-06-2005 10:40 PM
Setting the time. Hi-psi 3-Series (E36) 6 04-20-2003 01:17 AM
