Alternator??? - BMW Forum - BimmerWerkz.com
Old 07-06-2006, 04:45 PM   #1 (permalink)
Matty is an unknown quantity at this point
Alternator???
I have a 1985 318i and as of late it has been acting wierd. While I am driving the tach will suddenly begin to act possessed and jump around like crazy and it sounds like the engine runs a little rough, but not horribly so. If i floor it the tach catches and its ok for a while. If I dont see it and let it go, the stereo goes dead and possibly the headlights, but I dont remember. If the stereo and fan and everything are turned off it is less likely to do it. My only guess is the alternator or some sort of voltage regulator or something like that. Does this sound familiar to anyone??
Matty is offline   Reply With Quote
Old 07-07-2006, 06:26 PM   #2 (permalink)
DIRTE30's Avatar
DIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond repute
Send a message via Yahoo to DIRTE30
Sounds like your voltage regulator is going funny. Pretty tell tale symptoms. You can probably buy this piece at your local parts house for not too much. It is located within the alternator, pretty straight foreward installation. Should be an easy fix!
DIRTE30 is offline   Reply With Quote
Old 07-07-2006, 06:33 PM   #3 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
I replaced my alternator for $150...that includes a new regulator....I felt better replacing the whole thing, because it could be the regulator among other things....so i'd hate to replace it one peice at a time only costing me more in the end then a new alternator would cost....
but I guess that depends how much a regulator costs...
yammahamma is offline   Reply With Quote
Old 07-07-2006, 07:35 PM   #4 (permalink)
JoeMadoo's Avatar
JoeMadoo is on a distinguished road
Send a message via AIM to JoeMadoo Send a message via MSN to JoeMadoo Send a message via Yahoo to JoeMadoo
You could just take it to autozone and have them test it and the voltage regulator. An alternator either works or it dosent, its just a hunk of copper. A regulator is like 20 bucks.
86 Alpine White 335is M30 Swap <br>My Car Domain
ASE L1 Smog Certified
JoeMadoo is offline   Reply With Quote
Old 07-11-2006, 05:27 PM   #5 (permalink)
Well I just got her back from the shop and they said it was the battery indicator light. It was burned out and making intermittent connection. This is necessary to complete the circuit so what happened was that the alternator stopped charging and the computer was dying. They replaced the bulb and tested everything and now everything is fine. Hopefully someone else can use this information and not spend $100 to have a bulb replaced. But I never would have guessed that was it so it’s ok. Well I just got her back from the shop and they said it was the battery indicator light. It was burned out and making intermittent connection. This is necessary to complete the circuit so what happened was that the alternator stopped charging and the computer was dying. They replaced the bulb and tested everything and now everything is fine. Hopefully someone else can use this information and not spend $100 to have a bulb replaced. But I never would have guessed that was it so it’s ok.
new alternator 140amp(hurry help) moe_j 3-Series (E36) 6 03-12-2006 05:31 PM
alternator or battery moe_j 3-Series (E36) 6 03-06-2006 04:01 PM
e39 540i alternator and battery question HardStep 5-Series (E12,E28, E34, E39, E60) 5 10-11-2005 12:18 PM
Completed my Valeo to Bosch alternator conversion MOTRSPRT 3-Series (E36) 5 01-26-2004 06:16 PM
