how do you have an alignment problem? 90% of the time toe is the only adjustment you need, or else you have bigger issues
__________________ Kyle Sutherland
1995 BMW 540i/6: The Calypso Beast Vid 0-70ish 1987 BMW 325es: Face & Butt Lifted/M50tu Swapped*Sold* 1985 VW Scirocco: Too many mods, money pit*Sold* E34 Plate Filler Wanted!
Exactly. If you are having big alignment problems there is probably something bent that needs to be replaced. Is your car stock height? If it is and you are having a camber / caster issue there is something bent.
Ive been looking at this issue allso, check out this thread:
"Help!1 uneven rear tire wear on inside only, camber??? "
I lowered the car and now get a bit too much inside wear on my right rear.
See pics in other thread.
I know there are eccentric trailing arm bushings to correct minor issues, I think with the toe in. hmmm should work with a bit of camber too I think.
and my mechanic suggested the "next size up" sping pad to raise my right rear slightly to correct the camber.
I want to get in there and do some measurements first.
It might just be my subframe bushings.
I still need more info.
Laet me know what you find out.
__________________ Cheers,
Richard Fitz
'87 325is Delphin Metalic
