| When the engine is running ,and with a clear tube on the exit of the pressure valve regulator I can see very small bubbles coming from it.witch I can't understand why ,because like I said i do not see it coming from the pump. About the sound it's like if you blow on a tube inside a bucket,some times after the pump works and stop,if turn the key off and on I still have a little more bubbling.
Otherwise works ok.
Thank you. |
