Air In My Injector Lines - BMW Forum - BimmerWerkz.com
Old 02-01-2005, 07:48 AM   #1 (permalink)
gravney is an unknown quantity at this point
My 1980 320i was started after 2 years downtime
now it idles rough and air bubbles can be seen in the return line from the warm up regulator to distributor at one time then in either the #2 or #3 injector line
help
gravney is offline   Reply With Quote
Old 02-01-2005, 07:00 PM   #2 (permalink)
it may clear up on its own, but if not try running some quality fuel system treatment through, and see if that helps, if not you may have a major fuel contamination problem. In that case you would have to replace just about the whole system
Old 02-02-2005, 02:31 AM   #3 (permalink)
Kowalski's Avatar
help
[snapback]283979[/snapback]
check your fuel presure regulator, its vacume powered and the rubber lining might have cracked durring the down time and now your sucking air into the fuel, or you have a hairline crack somwhere in your line or on your fuel rail... but im leaning more to the regulator.
264* roatation and 388 lift
e39 540i Air Mass Sensor HardStep 5-Series (E12,E28, E34, E39, E60) 1 10-17-2005 10:15 PM
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
air bag light eugene 5-Series (E12,E28, E34, E39, E60) 2 10-10-2005 11:27 AM
AIR BOX DEBAFFLE *help please* White e36 dude 3-Series (E36) 6 09-10-2005 03:17 PM
