Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 06-16-2007, 09:13 PM   #1 (permalink)
photoguy30523's Avatar
Photos: 0
photoguy30523 is on a distinguished road
AHHHH is killing me (help)
my check engine light comes on, and throws code 1222 i have check everything there is NO vac leaks, fuel pump is new, AFM is new, it idles great what else can i check i am getting FU*K**G mad about it also my O2 sensor is new too. please what else can i check to get rid of this code.?
photoguy30523 is offline   Reply With Quote
Old 06-17-2007, 11:33 AM   #2 (permalink)
Car: Opening soon:
Photos: 0
Unfortunately there are many things that can cause code 1222. Here are a few things I have found over the years that have solved this code:
Have your valves adjusted if you hear alot of tapping at around 2500.
Check your intake boot for tears even small tears can open under load and will throw 1222.
Fuel pressure regulator, if it's off by 5 psi it can throw a 1222.
If your fuel injectors are very old and have a poor spray pattern can cause this code. I advise the late ford 5.0L HO or early 4.6L 4 pintle injectors. (the yellow ones)
If you car has a performance chip, take it out and see if it the code pops up.
Do a compression test, you should have no more than 20 psi deviation between each cyl.
Check your temp sensor. Also make sure you have the correct coolant temp sensor, there are two types: Blue and white. They will function if switched, however they are off by about 1000-1200 ohms cold 150-200 warm and 50-100 hot just enough to F with the DME and cause all kinds of weird and wondrous crap. The white should be used in the ETA powered cars 88 and older, the blue in 88 and up.
Don't rely on the auto parts place to give you the correct one, if you start spouting words like "ohms" or "I need the correct part" you'll scare those poor people.
And after you do any repairs, unplug the DME or disconnect the battery for 30 sec, longer if you have an air bag (the capacitor will take at least a 4-5 min to drain)
vB code is On
Ahhhh....finally got my car back. Teh Prof M-Series (M3, M5, M6) 7 02-07-2006 07:52 PM
1995 M3 keeps killing catalytic converters baddeye92 M-Series (M3, M5, M6) 3 07-14-2004 01:04 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
