aftermarket fuel pump from a Mustang? - BMW Forum - BimmerWerkz.com
Old 09-20-2004, 03:10 PM   #1 (permalink)
Smooth Criminal is an unknown quantity at this point
Hi
I bought a BMW 318 1991 and the car stalled a day after 'cause of the fuel pump
I need to change it, I don't know a lot about BMWs but would it be wise to put in a fuel pump that isn't BMW? an aftermarket Mustang fuel pump in this case
Smooth Criminal is offline   Reply With Quote
Old 09-20-2004, 04:14 PM   #2 (permalink)
Halon is an unknown quantity at this point
Send a message via AIM to Halon Send a message via MSN to Halon Send a message via Yahoo to Halon
I've seen a page of some guy who did a turbo onto his m10 (granted you have an m42 no doubt...) and he used a Mustang in tank fuel pump to help with his engines fuel greed... @_@ So I think you could do it. I dunno, talk to more knowledgable people.
Halon is offline   Reply With Quote
Old 09-22-2004, 12:15 PM   #3 (permalink)
enimik's Avatar
enimik is an unknown quantity at this point
I heard you can also use O2 sensers from a mustang?
Im as lost as a gopher in a rabbits hole...?
enimik is offline   Reply With Quote
Old 09-24-2004, 03:52 PM   #4 (permalink)
Thanks for the info
I'll keep that Mustang fuel pump in mind for the next time since I cheapened out and went for the rebuilt pump...
very disapointed...
Old 09-24-2004, 08:55 PM   #5 (permalink)
I don't think a Mustang pump would work right ghead
Old 09-24-2004, 08:56 PM   #6 (permalink)
BMW Lover's Avatar
BMW Lover is an unknown quantity at this point
Send a message via AIM to BMW Lover
i think it would let too much fuel in...its made for a much larger engine than the m42...i also have a 91 318is
^^I want this where I live.
"Drag racing a BMW is like going fishing with a hooker, it's fun but it's not what you got her for..." - M3DUDE
Manual - The transmission hated by moms/wives/girlfriends everywhere...
Member of the "I Owned my Bimmer when I was 17" Club
Member of the "10 Year Old" Club
Member of the "3 Pedal" Club
Member of the "3 Light" Club
BMW Lover is offline   Reply With Quote
Old 11-04-2004, 05:19 PM   #7 (permalink)
325iS's Avatar
325iS is an unknown quantity at this point
[snapback]198505[/snapback]
Actually, a higher volume pump will not hurt it as long as it is a return style system; I have not learned enough about BMW's to know what type they use.
In a return style system (as used in EFI Mustangs up to 1998), the fuel is feed through the fuel rails to a regulator. As the fuel reaches the pressure set in the regulator, it blows by and is retured to the tank via a seperate fuel line where it is recycled to be used again. When using a higher volume pump, the pressure stays the same (due to the regulator). The only difference is that more fuel is cycled in a given time.
FWIW, a stock 5.0L regulator is rated at 88LPH and I am currently running a 255LPH pump.
-Brian-
'88 Mustang LX coupe
- - - 11.56 @ 120 - - - 410 rwhp / 459 rwtq (Naturally Aspirated)
Hell yeah, it's a street car!
'92 325iS - - - - - - - - - 15.328 @ 89.70
325iS is offline   Reply With Quote
Old 12-06-2004, 08:52 AM   #8 (permalink)
idanity's Avatar
idanity is an unknown quantity at this point
i do know that your fuel pump should have about 90 psi ...
post some pics too...
and dont use the flash becuase fire is bad for bimmers. :P
member of the <span style='colorrange'>3 pedals club</span>
member of the <span style='colorrange'>195,000+ mile club</span>
<span style='color:red'> its the ones who cant even drive slow that think i cant drive better fast..</span>
idanity is offline   Reply With Quote
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 05:51 PM
Fuel Pump Location Biernacki 3-Series (E36) 3 02-16-2005 02:59 PM
Fuel Pump electronical Problem {NTM} 3-Series (E21, E30) 0 07-28-2004 08:08 AM
