adjustable cam ? explain/85 318i 1.8L - BMW Forum - BimmerWerkz.com
Old 10-11-2005, 01:03 AM   #1 (permalink)
j123crx is an unknown quantity at this point
they have adjustable cams, how do you do that ?
j123crx is offline   Reply With Quote
Old 10-11-2005, 11:27 AM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
You can get an adjustable cam gear to advance or retard ignition timing but you cant adjust anything on the cam itstelf. The only ajustable lift cams are on the new BMW V8's and V12's and even then the cam doesn't change they just mechanically change the pivot point for the rocker shaft which changes lift and duration.
My M50 Powered E30 Page
Old 10-11-2005, 08:22 PM   #3 (permalink)
Kowalski's Avatar
the M42's have adjustable cam gears, you can adjust 10 degreese on each cam i believe it was. if you adjust for more hp you loose torque if you adjust for more torque you loose hp so its a win loose situation...
to adjust the cam gears you just have to remove the valve cover the cam gear will be right there, you can loosen the nuts and adjust it, i dont recomend doing this yourself unless you are verry experienced...
264* roatation and 388 lift
Old 10-11-2005, 08:27 PM   #4 (permalink)
right...don't mess with it...got it
Old 10-11-2005, 08:36 PM   #5 (permalink)
Kowalski's Avatar
hahaha
Old 10-11-2005, 09:39 PM   #6 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
He has a M10 so he couldn't change anything even if he wanted to.
Old 10-12-2005, 11:30 PM   #7 (permalink)
i just heard it mentioned, didn't know what they were talking about...
Old 10-12-2005, 11:56 PM   #8 (permalink)
Kowalski's Avatar
i didnt say he had an M42 i was replying to your thread
as he has heard of the 318's having adjustable cam gears. i was telling him which engine did.
wheres the fuel filter ? 85 318i 1.8L j123crx 3-Series (E21, E30) 5 09-27-2005 11:06 AM
