ABS removal - BMW Forum - BimmerWerkz.com
Old 04-23-2004, 08:09 AM   #1 (permalink)
Le_max is an unknown quantity at this point
I know that the ABS controler is not bad on an e30 but mine dont work great.
I want to remove the controler under air filter box in front of the vehicule (driver side). I have a brake line job to do anyway so, my question is, is there anything I should know before removing all the ABS hardware? I will reroute the brake line directly out of the master cylinder to le wheel calipers.
thanks.
Le_max is offline   Reply With Quote
Old 04-23-2004, 09:49 AM   #2 (permalink)
Fox
Moderator
Send a message via ICQ to Fox Send a message via AIM to Fox Send a message via MSN to Fox
LoL, you are silly. I at first wanted to do this too. I mean hell it lets you have a lot more control of the car through turns and you can do cool tricks like spin around and do 180s and shit. However i put mine back in because after a full week of it my tires were already have worn through, especially on the edges. You will have to replace tires every month.
Fox is offline   Reply With Quote
Old 04-23-2004, 10:01 AM   #3 (permalink)
I can live with replacing tire every month!
When you say that you removed yours, you mean "disabled it" or "removed it"
I want to remove it! Is it just that simple, you remove the hardware and you reroute the brake lines?
Old 04-23-2004, 10:48 AM   #4 (permalink)
Fox
Moderator
I disabled it. Removing it is quite a task. I would recommend disabling it before you commit to removing it at least you can feel what its like, and youll find that unfortunately, ABS on an e30 does work pretty good.
Old 04-23-2004, 11:04 AM   #5 (permalink)
ok, thanks for the advice!
Old 05-04-2004, 09:46 AM   #6 (permalink)
followed your advice fox, I did not remove it.... I relocated it! The thing is that
I wanted to have more space in the front to fit a cold air intake in the engine bay.
The ABS controler was on my way. It is now on the passenger side, neer the wind
shield (I think it is where the batteries are on a 318i). I redone all
the brake lines (and gas lines... stupid calcium in Quebec) and lenghtened
the wires of the controler (12 wire total... 24 heads to solder ghead )
did not tried it yet, the car will only run in 3 weeks.
I was wondering, the abs controler is a little bit higher than the master cylinder....
do you guys think this will cause probleme when I will bleed the system?
HELP - Brake, ABS, and DSC lights on Fangs 3-Series (E46, E90) 48 05-13-2011 01:39 PM
ABS System failure!!Advise needed please. BMWstealth 3-Series (E46, E90) 9 10-12-2005 08:20 PM
valve cover removal ? j123crx 3-Series (E21, E30) 9 10-05-2005 10:20 PM
95 E34 Headlamp Assembly Removal newdad52001 5-Series (E12,E28, E34, E39, E60) 3 12-04-2004 08:02 PM
HELP!! need front bumper removal instructions KeyaraE36 3-Series (E36) 7 04-18-2004 10:45 PM
