Originally Posted by hk30 about 2 months ago my brakes got real spongy.....so i replaced the fronts it no help....backs seem fine...petel goes to the floor???? it hardly stops ....i got brake fluid .....need help im confused |
Your brake master cylinder is bad, it has an internal leak.......this is when the brake fluid leaks past the the piston because of faulty seals.....so when you press the brake pedal the fluid is not compressed & pushed out to each brake caliper, it just flushes back into the reservoir, thus the brake pedal going to the floor.
johnny,
Your Parts Search Returned 2 Part(s)
