My steering is loose and clicks with play when I move the wheel slightly back and forth. I can trace it to this coupling thing on the steering column but I can't find any info on that part. What is the fix for this? This would be a huge improvement in the steering response for my 318is.
Also, what are the options for upgrades for my steering rack? I'm looking to improve the ratio for more responsive steering.
OK..by "coupleing thing" do you mean the u-joint on the steering shaft or the reducer? If it is the u-joint, just replace it. If it is the actual coupler, chances are the splines may be worn, in wich case you may have no recourse but to replace the unit.
I know there are upgrades available to increase responsiveness, but what they are escapes me right now, i'll do some diggin.
I have heard of people swapping a e30 ///M rack, as well as a z rack, but i'll let you run those options down.
R.I.P fast 6
wow you are fast, fast like a bimmer. I was just coming to edit my vague thread post.
The part that is rattling is the universal joint. I can easily see that it has play in it and I can rattle it with my hand making the same noise my steering makes. This part is under the dash inside the car. After I posted I found info on what is called the coupling and I had that wrong.
I'm not trying to be lazy but I cannot find the proper name for that sucker to get a part # or a source.
Excellent. I'll start reading. It's possible fixing this u-joint will make me feel like I have a tighter ration alone and I'll forget all about a new rack.
I think it's this thing. This is from a used parts store but hopefully I can find a new one. It's riveted in place but I found a guide for drilling out the rivets and replacing with bolts.
The part I need is indeed the rubber in the coupler such as in my nice picture which I said was not the right part. It is that part. I believe it is sometimes called a rag joint.
If anyone has a source or a # for this rubber, you'd be a true hero.
you're a hero but a late one. Last week I lubed up and bought this part from the dealership for $204. I never hunted for an e36 version. Oh well, next time. thx again.
Yep, and if you notice I started this thread in Dec. Even with mucking it up myself, that makes 5 full months it sat here. Then within 6 days of bending over at the dealership, an OEM pops up here. Sooooo typical.
