91 318is Sputtering Problem - BMW Forum - BimmerWerkz.com
Old 07-03-2006, 01:14 AM   #1 (permalink)
MLC834's Avatar
Car: 04 Honda CBR 1000RR
MLC834 is on a distinguished road
First Time User,
I have a mint 91 318is, I just replaced fuel pump and fuel pressure regulator in hope to fix a Hot Start Sputtering problem. Car starts and runs fine initially, however, sputters after the vehicle has been runned then turned off.
Example, first thing in the morning car works fine, parked at work till lunch time, car starts fine but will sputter when taking off, this only occurs when vehicle engine is hot. I was told that it may be a thermo sensor relay, is this possible. Any suggestions, Thanks
Jay
MLC834 is offline   Reply With Quote
Old 07-03-2006, 10:09 PM   #2 (permalink)
Car: Opening soon:
Pull the spark plug boots out and take a look at them, look for dampness or oil soaked boots. An ECT sensor could cause that problem however it would kick a MIL.
Old 07-04-2006, 04:57 PM   #3 (permalink)
MLC834's Avatar
I've cleaned the spark plug cables on many occassions as a result of oil build up in the spark plug port. They appear fine, but I guess it's time for a new wire set. Thanks
Jay
Old 07-06-2006, 12:13 AM   #4 (permalink)
MLC834's Avatar
Replacing spark plug cable didn't cure the problem, o2 sensor works fine, car still sputters under throttle when hot. I live on Guam, never have to worry about cold weather starting conditions.
Still trying to figure out why car sputters only when hot and only after second start. Anyone have recommendations!
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
318is Electrical Problem mark30h 3-Series (E21, E30) 2 01-22-2005 06:21 PM
318is Problem ayrtons27 3-Series (E36) 2 12-11-2004 04:41 AM
Window Problem E36 318is Digital318is 3-Series (E36) 5 09-22-2004 09:28 AM
318IS heater problem jonniwal 3-Series (E36) 1 04-26-2004 12:37 AM
