89 325is fuel or elec problem - BMW Forum - BimmerWerkz.com
Old 12-29-2008, 08:27 AM   #1 (permalink)
jbv
jbv is on a distinguished road
I have a 89 325is, The car started like it was missing and slowly got worse now it will start but will only stay running 30 seconds or less. I have changed spark plugs, wires, dist cap, rotor, main relay, fuel pump relay, fuel pump, new ecu, pulse sensor, fuel filter, coil what else can it be at a loss
jbv is offline   Reply With Quote
Old 12-29-2008, 08:40 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
So, after it dies can you restart again straight away ?
Old 12-29-2008, 08:45 AM   #3 (permalink)
jbv
yes i can
Old 12-29-2008, 08:48 AM   #4 (permalink)
marti5's Avatar
I know youve done all the fuel parts, but it sounds to me like fuel starvation,have you changed the fuel filter.?
Old 12-29-2008, 08:51 AM   #5 (permalink)
jbv
yes, even checked all the fuel lines
Old 12-29-2008, 08:53 AM   #6 (permalink)
marti5's Avatar
Sounds like youve got air getting in to the fuel system, sounds strange take the fuel filler cap off and see what happens.
Old 12-29-2008, 08:53 AM   #7 (permalink)
jbv
the only thing i have not done is change the injectors
Old 12-29-2008, 08:55 AM   #8 (permalink)
jbv
i have done that it still does the same thing
Old 12-29-2008, 09:00 AM   #9 (permalink)
jbv
i dont know what else it could be
Old 12-29-2008, 09:03 AM   #10 (permalink)
marti5's Avatar
Have you cleaned the throttle body ?
Old 12-29-2008, 09:17 AM   #11 (permalink)
marti5's Avatar
If that doesnt work ,its down to one thing !!!
The Fuel Pressure Regulator #6 in the pic:
RealOEM.COM * BMW E30 325i VALVES/PIPES OF FUEL INJECTION SYSTEM
Old 12-29-2008, 09:33 AM   #12 (permalink)
jbv
ive cleaned the throttle body, the mass air flow sensor, and i have replaced the fuel regulator
Old 12-29-2008, 10:03 AM   #13 (permalink)
marti5's Avatar
Ok, You will need to check the pressure in the fuel rail, if thats ok, then you are looking at the camshaft sensor or crankshaft sensor, but Im still leaning towards a fuel problem, also check for any leaks on the air intake hoses.
Old 12-29-2008, 10:08 AM   #14 (permalink)
jbv
pressure at fuel rail checked out fine,i replaced the pulse sensor which some call it a crankshaft sensor
Old 12-29-2008, 11:17 AM   #15 (permalink)
marti5's Avatar
The crankshaft sensor is a different sensor than the camshaft sensor they are not one of the same. The crank...is situated normally down near the fly-wheel, cam.....is normally top front, so which one have you done.
HELP!! E36 92 325is Fuel Gauge Failure R_F_L 3-Series (E36) 4 07-18-2008 01:12 PM
Trouble removing fuel filter (92 325is) R_F_L 3-Series (E36) 5 04-11-2007 04:36 PM
1993 325is Fuel Filler Door FSCHW 3-Series (E36) 0 04-09-2005 11:41 PM
Diy For Fan Removal For Elec. One guywithblack88e30 3-Series (E21, E30) 0 02-19-2005 11:51 PM
WTB: Fuel Injector for 93' 325is zizux Classifieds Sell & Buy 0 02-02-2004 12:51 PM
