I've actually done this job myself and it's a bit tricky. You'll need to take all the belts of the engine to start with. I encountered two main sticking points, one was the fitment of the replacement pump, it's tricky to make sure you don't put a kink in the gasket when you fit the new pump. Poor visibility and a need to rotate the unit on it's bottom of the three bolts means a kink is real possibility. I actually did kink the gasket on my first attempt and water leaked everywhere when I tested it. Don't forget a sealing compound, but use the blue stuff!!! You don't want the stuff that goes off and hardens
The second issue to be aware of is the refitting of the cam belt tensioner. It's just damn awkward to be honest. I used a cable tie to take some compression out of the spring whilst putting it back in place. You can then cut the cable tie once it's fitted.
One other hint - It's a lot easier to get the fan off the old pump whilst it's still attached to the engine block, you'll have to take off the 4 pully wheel bolts which secure it so you can get at the bolt securing the fan to the pump. The haynes manual covers most of this job reasonably well but I wouldn't recommend this if your not vaguely happy with spanner in your hand! Good luck
__________________ </div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE </td></tr><tr><td id='QUOTE'>It's no the pace of life that bothers me...it's the sudden stop at the end! </td></tr></table><div class='signature'> |
