89 325i running problem - BMW Forum - BimmerWerkz.com
Old 01-03-2009, 12:40 AM   #1 (permalink)
tech9 is on a distinguished road
Car was taken to corner store, upon leaving car was running rough and was smoking a lot from the tailpipe. Got the car home, checked oil (no water) checked water (no bubbles). Replaced spark plugs, checked all connections, fuses, etc. Now its even running rougher and having a very very hard time to start. It only runs for a few seconds unless you really feather it.
Not sure where to start as I never have dealt with a BMW before, just bought this car less then a month ago and it was running great since.
Plugs smell like gas, and they are getting spark, i'm thinking maybe timing? compression test is in order next.
TIA
-Joe
tech9 is offline   Reply With Quote
Old 01-03-2009, 06:56 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
The smoke from the tail pipe, was it smoke or condensation and did it have a gas smell or some other smell ??
Old 01-03-2009, 10:47 AM   #3 (permalink)
I wasn't driving it, the person who was driving said "white" smoke, but you never know.
Old 01-03-2009, 10:49 AM   #4 (permalink)
Maybe it's an ignition issue; I'd have a check of the distributor and spark plug leads. Have the valves been adjusted? While you're at it, you may wanna find out how old the timing belt is.
Old 01-03-2009, 12:14 PM   #5 (permalink)
Valve adjustment is just like any other car? This is solid lifter ohc correct?
Going to check compression, all the ignition stuff asap.
Thanks
Old 01-03-2009, 12:33 PM   #6 (permalink)
I never really got a look in my M20, but I have read that there are no actual lifters; the cam runs along the middle of the rocker arms.
Old 01-05-2009, 08:25 PM   #7 (permalink)
change the fuel pressure regulator.....I'd do it...first ...myself...good luck
silversled is offline   Reply With Quote
Old 01-05-2009, 08:27 PM   #8 (permalink)
I do the valves every 6 months on my 1988 325ic...it's good to do
Old 01-09-2009, 12:15 AM   #9 (permalink)
cal325ix is on a distinguished road
Check that air stabiliser valve is functioning, no air leaks in inlet manifold + check fuel pressure
cal325ix is offline   Reply With Quote
Running problem with an '85 325e. Help? StoneyBlouse 3-Series (E21, E30) 1 08-08-2007 12:11 AM
Idle/Running Problem toymachine595 3-Series (E36) 2 06-20-2006 01:50 AM
poor running 325i NYRallyChick 3-Series (E21, E30) 2 11-10-2005 02:19 PM
88 528e Running Problem lazerboy 5-Series (E12,E28, E34, E39, E60) 0 03-04-2005 11:45 PM
Engine Running Big Problem,help Reckless666 5-Series (E12,E28, E34, E39, E60) 2 02-06-2005 05:14 PM
