Hi I will be looking at a '88 325i this weekend and have a couple concerns and questions you might be able to help me with.
The current owner (a BMW/ Mercedes mechanic) said he had to replace the camshaft about 6 to 8 years ago because his mother (former owner) would only cold start and take short trips. should I be concerned that this would/will cause further engine problems down the road?
It has only 71,000 miles, and he gave me a list of work he has done on it that I don't have in front of me. Outside of a rust spot in the right back wheel well and some dings it seams to be in pretty good shape. He wants $1,800 for it but I may be able to get him down to 1,500 b/c it only has snow tires.
Is there any other known issues I should be looking for or specifics that could help me out? Any advice and pointers would be really appreciated.
Thanks guys
Reason: typo
The cam being changed out should not cause any issues. Being he is a BMW mechanic, that would make me feel better about buying the car. Also, 1500 is a good price for that car. Good luck.
__________________ FCP Groton
877-634-0063 | info@fcpgroton.com FCP Euro - European Car Parts Specialists FCP Import - Import Replacement Car Parts
6-8 years ago installed a new camshaft ( stock ) and port and polished the head with 3 angle cut valve job (worn cam lobes due to lack of use ) . At this point started to use synthetic oil (started with syntec then bmw oil then luqi moly ) . 04 Radiator 05 Control arms 07 Tie rod 08 Catalytic converter, muffler, o2 sensor, oil pan, oil pump & battery . 09 timing belt & tensioner, fan belts , water pump , coolant flush , distributer cap & rotor ( spark plugs have +/- 3000 miles )
Can anyone think of things I should be on the look out for when I test drive it?
Is it an auto? Smoothness of shifts. Other than that you should be good for another 70k besides regular maintenance. Depends on how you drive and what you plan to do with the car. I drive like an a-hole most of the time so my car requires more attention than others.
Sounds like your getting a pretty good deal on the car, I paid seven hundred for mine and have about thirteen hundred into it. Mine also has like 240,000 miles on it(odometer stopped at 222,093).
that many parts replaced with only 71,000miles raises a RED flag with me.
The Q. Why replace CAT, oil pump? at 71,000. hmmm. that is not normal. (i know that bimmers have CAT weakness-but definitely not at 71K on a well-maintained engine)
which leads me to think... some major engine damage before 71,000? Nobody but NOBODY changes oil pump for no reason. And plus oil pan, CAT muffler and control arms - that raises an eyebrow(especially if receipts show it was done all at the same time).
I bottomed out with mine one time, got the pump with the pan so put it in anyways. By the looks of the pics, it looks way to nice to be selling for such a low price. Do you know the guy at all or is it a dealer of somesort?
The control arms probably got messed up when he busted the oil pan.
The car looks like it is in good shape over all. I have to agree with the other guys about the oil pump going. Leads me to believe that the cam issue may have happened because of lack of oil or something like that. Maybe give him a grand for it. IDK, I would have to see it and feel him out.
