88 325i, what's the fuel pressure? and other ??s - BMW Forum - BimmerWerkz.com
Old 08-27-2004, 11:49 PM   #1 (permalink)
draculia is an unknown quantity at this point
pretty straight foward question, what's the base fuel pressure?
and for the hell of it, i just picked up the above-mentioned car. 5 speed, 135k miles, i payed 1900. it needs a new wheel bearing, some dash lights are on, and 3 injectors and the fpr are leaking. to cure the fpr leakage, i'm just gonna install one of the adjustables i have laying around, hence the reason for my question.
also, what are the stock injectors rated at? doesn't matter if you give me the data in lbs or cc. how about the fuel pump? compression ratio?
anyone have a link or pick to a diagram of what the dash lights each represent?
last ? for now, anyone know where to pick up a clutch kit that isn't a stock replacement? i've looked a little, but haven't found anything.
draculia is offline   Reply With Quote
Old 08-28-2004, 01:32 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Fule pressure at idle should be arround 40psi. As far as your other questions I'm not sure, pick up a Haynes or Bently manuel and I'm sure you'll find it in there.
My M50 Powered E30 Page
