| check fuel lines. sounds like maybe you have a bad hose, perhaps a pinhole letting fuel drain back through the line. First crank won't get the fuel all the way up, but by the time you cycle the fuel pump again it is good enough to run.
__________________ R.I.P fast 6
Two wheels or Four, I'm happy as long as the throttle is pinned. |
