87 325is small problems - BMW Forum - BimmerWerkz.com
Old 12-27-2008, 11:48 AM   #1 (permalink)
blazein is on a distinguished road
Question 87 325is small problems
I have a new performance chip for my car how do I un solder the old one.
Also where can I get u joints for this car.
And last but not least How can I trouble shoot the automatic kick down button under the gas peddle. Thank you
blazein is offline   Reply With Quote
Old 12-28-2008, 07:05 AM   #2 (permalink)
Jedz123's Avatar
Car: 1986 BMW 325e
Jedz123 is on a distinguished road
Send a message via AIM to Jedz123
the old chip is located on a bay of sorts... It should just come off and you just clip in the performance one. No soldering required...
U joints are usually sold complete with drive shafts. CV (Constant Velocity) joints or ball and cage joints are usually sold with drive axles. I'm sure you can order drive axles from you local parts store. Expect to wait at lease a week for delivery though. Drive Shafts might be more difficult to acquire for I have never seen one need replacing, except when my uncle snapped the one on his vette...
Not sure about the Kick down button... I tend to avoid Dogomatics like the plague...
Good luck!
MY Cars:
1986 BMW 325e
1990 Mazda Miata MX-5
My Bike:
1981 Honda C70 Passport
MY Passion:
Anything with an internal combustion engine.
Jedz123 is offline   Reply With Quote
Old 12-28-2008, 11:20 AM   #3 (permalink)
Cool wrong?
Am I incorrect that the chip is located on the circuit board inside the ECU?
Thanks to all
Old 12-28-2008, 05:42 PM   #4 (permalink)
Jedz123's Avatar
Car: 1986 BMW 325e
Yes the Chip does go into your ECU.
Your going to have to open the monotronic unit up, I took off both top and bottom of it and you will see that there is two boards one of the boards will open out of the unit like a book. On that board you will see 3 black chips and one of the chips will be sitting on a black conecter bay thing. It will be more elevated then the other chips. Just gently slide a screwdriver underneathe it and it should just pop out. Then just install your new chip, put it back together and reinstall! Should work if it doesn't you might have put the chip in backwards so make sure you put it in right the first time...
The ECU is located behind the glove box hanging from under the dash...
Good luck!!
MY Cars:
1986 BMW 325e
My Bike:
MY Passion:
Old 01-01-2009, 06:09 PM   #5 (permalink)
Thank you for your reply, My problem is the Ecu is a Bosch numbers ending in 525. There is only 1 card in it my son and I counted pins on the 3 chips and found one of the same pin count and mm. dimensions, but all the darn chips are soldered in place. Any ideas I hate the young fellow can't use is gift. Thanks all, Blazein
Old 01-02-2009, 05:46 PM   #6 (permalink)
Crispy1st's Avatar
Car: 1987 BMW 325, YZF 750 yam
Crispy1st is on a distinguished road
Here is what my chip install looked like. The arrow in the middle photo is showing how the rubber stopper is holding the board on. And the arrow in the right photo points to the chip that I replaced. Don't know if its the same sorta one you have but there it is.
87 325is small  problems-chip1.jpg   87 325is small  problems-chip2.jpg   87 325is small  problems-chip3.jpg
Crispy1st is offline   Reply With Quote
Lot Of Small Problems With My 95 Bmw 318is matt_5112 3-Series (E36) 1 04-23-2005 11:44 AM
Small Problems On My 1996 E36 Rooz 3-Series (E36) 4 01-14-2005 09:05 AM
Small, Stupid Problems.. epheterson 3-Series (E36) 2 12-05-2004 07:23 AM
1990 325i small problems met79965 3-Series (E21, E30) 3 08-04-2004 11:02 PM
a couple small problems cronus10 3-Series (E46, E90) 0 07-10-2004 06:20 PM
