87 325es Coolant Warning Light Stays On - BMW Forum - BimmerWerkz.com
Old 06-01-2009, 11:56 AM   #1 (permalink)
Car: 1987/BMW/325es
terriibleted65 is on a distinguished road
I have filled the coolant to the recommended height but the coolant light stays on. Any suggestions?
...just bought the car this weekend so I am going through the issues I find...thanks for your help and sorry if this is a repeat post as I could not find this topic. - Ted
terribleted65 - new to bmw restoration but have restored 63 ford fairlane and 68 mustang conv. I look forward to the bmw experience.
terriibleted65 is offline   Reply With Quote
Old 06-01-2009, 12:20 PM   #2 (permalink)
There's likely air in the system that must be bled out.
Old 06-01-2009, 07:53 PM   #3 (permalink)
Car: 1987/BMW/325es
drain and fill, work?
i was going to perform a drain and refill on the coolant anyways since there are no records on when it was done last...will this likely remedy my 'air' situation?
Old 06-01-2009, 08:31 PM   #4 (permalink)
Only if the air is carefully bled out.
Old 06-01-2009, 09:16 PM   #5 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
My e30 had the same issue Normally it is the sensor has gone bad there cheap to replace...
1992 318i Coupe parts car
I am Captain Obvious
Old 06-17-2009, 04:32 AM   #6 (permalink)
sunkist_drop's Avatar
Car: 08 MB C300,
sunkist_drop is on a distinguished road
Send a message via Yahoo to sunkist_drop
You have a pic of the sensor??
sunkist_drop is offline   Reply With Quote
Old 06-17-2009, 09:30 AM   #7 (permalink)
romeomike's Avatar
Car: 91 318i, 90 325iC, 2004 325i
romeomike is on a distinguished road
Part #5
RealOEM.com * BMW E30 325e EXPANSION TANK
romeomike is offline   Reply With Quote
Old 06-17-2009, 07:20 PM   #8 (permalink)
what I do is fill the coolant resevour a little at a time while the engine is just a little bit warm, so that the cap comes off without spraying stuff all over the place but keeping the thermostat open...there's a point in there where you have both conditions...then I top the coolant off a little bit at a time and squeeze the radiator hoses one by one until no squishing sound. I always see the coolant level in the tank lower, then I add more coolant and do it again...eventually the system is stocked......button it up and there you go...good luck....
silversled is offline   Reply With Quote
Old 06-18-2009, 05:19 PM   #9 (permalink)
Car: 1987/BMW/325es
thanks. i had a complete flush and fill done on the coolant system and I am still seeing the light. probably a bad sensor at this point. will try that.
Old 06-18-2009, 06:48 PM   #10 (permalink)
whatever, the only thing that trips the telltale lamp in the cabin is the cap on the overflow/filler tank.....that's it....try tapping the plunger on the cap and see if doesn't release....just a guess, but's that only thing that triggers that light...now...if the temp gauge runs high that's an issue.....
Old 10-05-2009, 04:48 PM   #11 (permalink)
Car: 1987/BMW/325es
changed the sensor this weekend...fixed the issue immediately...now I wish all of the repairs were that simple. :-)
Problem: Coolant Warning Came on Lastb0isct 5-Series (E12,E28, E34, E39, E60) 6 03-16-2006 07:29 AM
523i And The Warning Light Stays On DuncanThomas 5-Series (E12,E28, E34, E39, E60) 1 11-05-2004 04:38 PM
Coolant Level Warning 91525i 5-Series (E12,E28, E34, E39, E60) 2 08-06-2004 10:32 AM
Warning about using water as coolant nycbmw325is 3-Series (E36) 7 08-05-2004 04:18 PM
Light stays on Toxic 5-Series (E12,E28, E34, E39, E60) 2 03-22-2004 12:36 PM
