87 325e no spark..PLEASE HELP!!!!! - BMW Forum - BimmerWerkz.com
Old 02-02-2010, 04:00 PM   #1 (permalink)
woobagooba152 is on a distinguished road
Exclamation 87 325e no spark..PLEASE HELP!!!!!
ok guys heres the deal. ran good, seemed to start a lttle hard, but may be normal, not sure, just got the car. drove it fri, and sat. sun morning installed a new radio in it. sat all day sun till early evening, got in it to leave , wont start. Has fuel, but no spark from the coil. First thought, replce coil, didnt work. i have 12v at + side of coil w/key on, and 12v on - side as well at all times w/key on ,no pulse when it cranks. Pulled crank sensor and it tests in spec(at least i think so, got info online). some corrosion on terminals, but i dont tink thats problem. I ordered a bently, but untill i get it im not sure of the relay locations. his sems to be a common problem but i have not seen anyone that has this exact problem. I also tried removing the radio(just a thought) didnt help either. is there any oter tests for the cp sensor? I have fuel, so the pumps are working? Any help you experts have would be appreicated. This is my second bmw, and the first time i had any problems like this.
woobagooba152 is offline   Reply With Quote
Old 02-15-2010, 01:25 AM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Arrow
Where did you test for spark?
In no start conditions aside from checking at the plugs... you also need to check for spark at the coil wire.
Measure voltage at coil. if at least 11.5; then,
Check - spark at coil, but no spark at plugs.... then suspect distributor cap n rotor.
No spark at coil. check all fuses, and main relay.
Good Luck
Old 03-02-2010, 01:05 PM   #3 (permalink)
Car: 1990 BMW 735iL
beamers4life is on a distinguished road
Id say check the fuses and main relay as well as checking the ignition relay all in the fusebox. See if any of the leads have blackened as a result of shorting or something
beamers4life is offline   Reply With Quote
no spark k.sidlosky 3-Series (E21, E30) 12 01-27-2009 06:14 PM
help me find the right spark plug for a 325e träumer 3-Series (E21, E30) 4 10-12-2005 03:39 PM
86 325e And No Spark Please Help *Update* quiklilrex 3-Series (E21, E30) 11 09-21-2005 09:25 PM
86 325e And No Spark Please Help quiklilrex 3-Series (E21, E30) 18 09-16-2005 01:16 AM
