87 325 fuel gauge is intermittent - BMW Forum - BimmerWerkz.com
Old 10-14-2010, 05:14 PM   #1 (permalink)
CDA
CDA is on a distinguished road
I'm restoring a 87 325. love this car, fun to drive.
there's some issues with the electric windows, check engine/ coolant lights.
The fuel gauge is intermittent, works for awhile, then goes to empty. Has anyone had this problem. Is there a fix without removing the dash?
Thanks
CDA is offline   Reply With Quote
Old 10-14-2010, 07:20 PM   #2 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
Remove cluster, there is a hex nut that can be tightened.. usually a loose ground.
Old 10-17-2010, 05:44 PM   #3 (permalink)
CDA
How do you remove the instrument cluster?
Thanks
Old 10-18-2010, 04:39 PM   #4 (permalink)
crusheroz is on a distinguished road
I've done this so many time but I forgot how many screws are on the bottom but there are two up top for the cluster black outer ring and I think a couple of screws under the panel right above the steering column, you have to take the pedals kick panel loose to unscrew thumb nuts, one on each side and then under that is more screws. The cluster has four screws holding it in, two up top and one on each side. Once those are out, you have to wiggle it out, TOP FIRST and then swing it to one side. Its do-able, just have to finaggle it out. In order to get it out all the way, there are plugs on each side, a simple small flat head will help. You have to have small fingers to get them back on though. Enjoy.
crusheroz is offline   Reply With Quote
318' E36 Fuel Gauge And Temp Gauge Problems Help!! mrfunk 3-Series (E36) 7 04-28-2010 05:22 PM
intermittent gauge problem on my 95 m3 HELP!! My3rdBimmer M-Series (M1, M3, M5, M6) 4 08-16-2006 09:25 PM
intermittent gauge problem on my 95 m3 HELP!! My3rdBimmer 3-Series (E36) 5 08-03-2006 01:20 PM
Fuel Gauge 4griswalds 3-Series (E46, E90) 3 08-10-2005 08:24 PM
Fuel Gauge rakeshp 5-Series (E12,E28, E34, E39, E60) 4 06-10-2005 10:49 AM
