87 325 - BMW Forum - BimmerWerkz.com
Old 04-08-2004, 08:08 PM   #1 (permalink)
viali8 is an unknown quantity at this point
is it difficult to change the oil in the differential. i know that it is a heavier oil and was wondering what the best way was to get the new oil in the differential. any advice would help. thanx in advance. viali8
viali8 is offline   Reply With Quote
Old 04-08-2004, 09:48 PM   #2 (permalink)
on the rear side of the diff ( facing you if you're looking at from under the back of the car) there are two caps/valves, i dunno what theyre called, one to drain (bottom) and one to fill (top). open both to let the fluid drain out, then close the bottom one and pump fluid through the top hole. there deffinately is not a way just to pour in the oil, so unless they make special tools to fill it up, the only way to get the new oil in is to pump it in
Old 04-09-2004, 12:48 AM   #3 (permalink)
thanx for the info mrm3 i will give it a shot. have a nice holiday.
ps. what did you use to "pump" the oil?
Old 04-09-2004, 04:31 PM   #4 (permalink)
DeathMetal's Avatar
DeathMetal is an unknown quantity at this point
You need a 10mm hex wrench. Open the top one first, then the bottom one. To refill, you need either a big syringe or a pump. The pump I'm talking about looks just like the push down pump that's used on a bottle of Vaseline - with a hose attached to it. You can either make you rown or buy one at an auto parts store for less than $3.
<span style='color:blue'><span style='font-size:14pt;line-height:100%'>Member of the Out of the Closet &quot;I Listen to Metal and own a Bimmer&quot; Club</span></span>
DeathMetal is offline   Reply With Quote
Old 04-10-2004, 01:16 PM   #5 (permalink)
thanx deathmetal. looks like i gotta make a trip to pep boys.
Old 04-10-2004, 03:47 PM   #6 (permalink)
greenlightracer is an unknown quantity at this point
Send a message via AIM to greenlightracer Send a message via MSN to greenlightracer Send a message via Yahoo to greenlightracer
What kind of oil do u want to use in a diff.? I have a 90 325i if that makes a difference...
greenlightracer is offline   Reply With Quote
Old 04-10-2004, 09:28 PM   #7 (permalink)
i have an 87 325 and in the haynes manual 3 and 5 series it recommends
API GL-5 SAE 90-hyoid gear lubricant. your 90 325i would take the same. thanx
dyno results on real whp 325 vs 330 vs 328 dzenisn 3-Series (E46, E90) 23 12-01-2008 07:10 PM
325 Is auto tranny into a 325 I sesone 3-Series (E36) 1 10-31-2005 01:38 PM
1988 325 to try or not to try? Stigler 3-Series (E21, E30) 24 09-28-2005 03:53 PM
NEW MATCHING SHIFT & E-BRAKE BOOT SET BMW E30 318 325 customshiftboot Aftermarket Parts 0 09-13-2005 10:59 PM
Ready to buy a 325 wagon zachlail 3-Series (E46, E90) 0 09-11-2005 01:25 PM
