86 Idel Problem (help) - BMW Forum - BimmerWerkz.com
Old 02-18-2006, 04:06 PM   #1 (permalink)
Skatebline's Avatar
Skatebline is on a distinguished road
Exclamation 86 Idel Problem (help)
My 1986 325es is ideling from 600 to 1000 rpms and sometimes to 1200 rpms mostly all the time. I was wondering if anyone would probly know the reason that its doing that?
Skatebline is offline   Reply With Quote
Old 02-18-2006, 06:01 PM   #2 (permalink)
Car: Opening soon:
That sounds like a faulty idle control motor, make sure you don't have any intake leaks, especially around the flex sections of the intake boot (very easy to miss there). Then unplug the idle control motor and see if it jumps up and down. If the idle stops fluxuating, replace the motor. If it's still fluxuating you may have a dead spot in you air flow meter.
Old 02-19-2006, 02:35 PM   #3 (permalink)
Skatebline's Avatar
Alright im gonna have to try that. i was thinking it could be the idel control motor too, if its bad im am i gonna have to buy a new one or is there a way of fixing it? How much do they run for?
Old 02-20-2006, 07:49 PM   #4 (permalink)
Car: Opening soon:
Sadly they can't be fixed. They go for around 150 new, used ones are about 30-40 bucks.
Old 02-21-2006, 05:20 AM   #5 (permalink)
Paraklas's Avatar
Car: 2001 E46 320ci with ESS TS2
Paraklas is an unknown quantity at this point
I have a working Idle Control Valve taken of my 1989 E30 318i M40 Engine, T-Shape Bosch if anybody wants it. I thought it was problematic and I bought a new one cause I had bad idle but in the end the air flow meter needed adjustment.
Paraklas is offline   Reply With Quote
Old 02-21-2006, 08:56 AM   #6 (permalink)
Skatebline's Avatar
The Air Flow meter is the Mass Air Flow sensor right? or is it a different thing
Old 02-21-2006, 09:51 AM   #7 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
That Idle Control Valve is touchy. I was cleaning a bit under the hood and I guess I bumped it because when I started my car up, it did the 600-1200 idle thing. Good thing I know what to do. disconnect, wiggle, reconnect. Good as new!
My BMW Blog
Old 02-21-2006, 05:58 PM   #8 (permalink)
Car: Opening soon:
It's called the air flow meter because it measures the volume of air with a flapper door not the actual mass as the mass air flow meter measures the mass of the air by measuring the amount of electrical resistance the heated sensor wire has. Less air hotter the wire is, more air cooler the wire is.
Old 02-21-2006, 06:00 PM   #9 (permalink)
Car: Opening soon:
If you car is and 86, you have the L shape two wire style idle air controler.
Old 02-22-2006, 09:30 AM   #10 (permalink)
Skatebline's Avatar
So you think if i just unplug the idel control then wiggle the prongs then plug it back it in, it should work. What if i do that and nothing happens.
Old 02-22-2006, 06:23 PM   #11 (permalink)
Car: Opening soon:
Just unplug it while it's running, the rps should go up about 100-300 rpm and then hold steady.
This won't fix it, but it will tell me and others what else may be wrong.
Old 03-08-2006, 09:07 AM   #12 (permalink)
Skatebline's Avatar
Well i did that and it reved up about 300 more rpms and stayed up there for a little bit then it would start reving up and down until i would plug it back in.???
528i Alarm Problem Xero 5-Series (E12,E28, E34, E39, E60) 5 01-03-2011 01:16 PM
Perplexing Problem Starting my 87 528e arkhaus 5-Series (E12,E28, E34, E39, E60) 5 02-04-2006 08:17 AM
Drive Shaft Problem... 97alpineM3 3-Series (E36) 9 12-02-2005 03:33 PM
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 0 02-28-2005 07:33 AM
