86 bmw 325es starting problems - BMW Forum - BimmerWerkz.com
Old 01-08-2010, 06:49 PM   #1 (permalink)
Car: 86 bmw 325es
grandersyo is on a distinguished road
i have a bmw 325es i tryed to start it and it shut off because it was cold but it did this about 10 times and now when i try it, the starter seem like it isnt connected or somthing it wont even tick its done this before but i cant figure it out. i tryed to hook up a charger to it if the batterie isnt working but the fule pump works so its not the batterie.
grandersyo is offline   Reply With Quote
Old 01-09-2010, 06:06 AM   #2 (permalink)
Car: 1988 BMW 325i Convertible Navy Blue
Kennethdriley is on a distinguished road
Starting Problems
Be sure and check to see if the starter is grounded good. I know it sounds weird but even though the casing is bolted to the engine it still may not ground good. I ran a wire from one of the bolts on the end of the starter motor to the shock tower ground by the battery to fix mine. Try to use a jumper wire from the positive battery to the outside terminal on the selenoid and see if you get anything if it isn't the ground. Hope this helps
Kennethdriley is offline   Reply With Quote
BMW E39 525TDS 1999 - Starting problems was4 5-Series (E12,E28, E34, E39, E60) 4 11-05-2011 02:52 AM
BMW 318 Starting Problems any ideas? toni_01 3-Series (E36) 5 09-15-2009 12:24 PM
1992 BMW 320i starting problems aedwards0909 3-Series (E36) 0 05-09-2009 02:13 PM
BMW E36 Starting Problems ldencer 3-Series (E36) 2 09-16-2008 03:17 AM
BMW 318i 92Model E36 Starting Problems deanbelich 3-Series (E36) 7 09-21-2005 11:41 AM
