86 325es Wont Start PLEASE HELP! - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 03-12-2014, 07:01 PM Thread Starter
SuicideKid is on a distinguished road
Hi,
I Hope somebody can help me. My Daughters Boyfriend bought an 86 325es, it ran rough, but it was in really good shape, with a New Trans. well, I Changed Air Filter, ICV, Fuel Rail, Fuel Pump, Filter, 2 Injectors, Mass Air Flow sensor. While working on it, the Battery died..... There was an after market alarm on it, but no Remote, and I cant find the Alarm Box. I Found the Shock Sensor, and removed it, as well as any wire that did not look Factory. Battery being Dead, we tried to Jump Start it, and I hear the Re-Lays engage when the ignition is turned on, but the Starter does not engage. I Have power to it, but, it wont start..... There are 3 wires to the starter, 2 big ones and a Small probably 14g. with a spade connector on it that goes to a terminal between the 2 Larger wires. Also, when I try Grounding the Starter to get it to engage, Nothing...... Please help, I am all out of ideas....
Thanks,
Dave
SuicideKid is offline
post #2 of 3 (permalink) Old 04-08-2014, 01:33 PM
Quoted: 1 Post(s)
grooverben is on a distinguished road
[QUOTE=SuicideKid;680090]Hi,
Check Earths to body, maybe Solenoid is faulty(Starter Motor wont engage if Solenoid is no good), has it blown any fuses? I am probably not the person to help you as I am new to BMWs myself(Recently got a 1989 E30) however that would be my best guess. Hope that helps mate as BMWs are great cars and worth the effort
grooverben is offline
post #3 of 3 (permalink) Old 04-12-2014, 11:24 PM
m20enginebuilder is on a distinguished road
Protip- being a mechanic, I know easy ways to test starter solenoids. find the lead that comes out of the solenoid to the starter. put power to it by using a jumper wire, or an external battery with jumper cables. make sure you connect a ground. if the starter spins, then its got a bad solenoid. Also, CHECK THAT GROUND STRAP THAT CONNECTS TO THE OIL PAN! That is the MAIN ground for EVERYTHING on the engine. If its NOT connected, you WILL NOT have a working starter. Trust me, I know from experience!
m20enginebuilder is offline
1986 E30 325es Won't Start minadoss 3-Series (E21, E30) 45 01-01-2011 02:11 PM
1986 325es SMOKES, HARD START, BAD IDLE !!FIX!! kenika65 3-Series (E21, E30) 1 03-22-2007 10:29 PM
95 318ic wont start, egine wont turn over. (couple cold days) vic318ic 3-Series (E36) 2 02-05-2007 10:00 AM
Wont start linx76 5-Series (E12,E28, E34, E39, E60) 4 01-27-2004 03:03 PM
