86 325es 2.7L turbo?? Posiible?? - BMW Forum - BimmerWerkz.com
Old 05-02-2006, 01:42 PM   #1 (permalink)
SLEEPYDUB is on a distinguished road
Alright guys, im new to the forum, i dont own a BMW but my friend does and he doesnt have internet access, so he relys on me to do his research for him, which i dont mind.
First off, im in the process of Turboing my VW Bora, 24v VR6, GT35r Turbo, 034Motorsports standalone, etc etc etc.
Anyways,
I was wondering if i could gather some info on turboing the 2.7L motor that came in the 325es in 86.
Who sells a kit?
if there is no kit, who sells the parts, i.e., manifold, chip, etc.
im trying to steer him away from doing a 95 325i motor swapm only said to be like 180hp or something?? i think a turbo setup would be better.
Can anyone help out a nOOb??
SLEEPYDUB is offline   Reply With Quote
Old 05-02-2006, 06:53 PM   #2 (permalink)
Car: Opening soon:
Yes, I'm doing the same thing, however with 9:1 compression raito boost over 4-5 lbs gets you into trouble fast.
Now that I have gas (for my welder that is) I'm going to finally build my inexpensive turbo manifold that I designed for bugget builders. If interested we can talk about setting him up with one for a good price.
BTW, I find that odd that they call the VR6 a DOHC. The VR6 is really a V6 with one cylinder head and one cam runs each bank. To be technical about it the VR6 is in reality a SOHC because to "truly" be a DOHC you need 4 cams per bank.
Old 05-03-2006, 01:24 AM   #3 (permalink)
they changed the engine when they went from the 12v to the 24v, it is now a DOHC and can support 500whp on 8:5:1 compression. It is also offset 15 degrees instead of 45 or 30, its almost like a inline six. VR6 translates to Vee-Rehein motor six cylinder, which means Inline Vee. Crazy germans
Old 05-03-2006, 09:46 PM   #4 (permalink)
raytech's Avatar
raytech is on a distinguished road
how much boost you add will be directly dependant on how much fuel you add as well as how cool you can get the intake charge.
With that much compression, you will be limited due to the fact that the pistons and valves are not made for high cylinder pressures and heat. It also does not help that there are no piston squirters to help cool the pistons as well.
Anything can be boosted, as I am sure you already know with previous experience.
raytech is offline   Reply With Quote
Old 05-03-2006, 09:48 PM   #5 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
yes anything can be boosted with enough prep... if you boost to high and the pistons arent made for the pressure... well yeah bye bye pistons... there is always some prep in changing parts if you want to go crazy with boost...
Old 05-04-2006, 07:12 PM   #6 (permalink)
Car: Opening soon:
Melted pistons, blown head gaskets and burnt valves are most common. For boosted motors lower compression pistions are better, ideal ratio is close to 7.5:1 to 8:1.
Here is a few guide lines for turbocharging motors:
#1 For every 1 psi of boost raises the compression raito about .5 psi.
#2 For every 1 psi of boost raise the octaine rating by 2-3 points.
#3 1 psi of boost raises your ambient air temp in the intake by about 12-13 degrees F
#4 For every 10-15 degree raise in ambient air temp raise the octaine rating by about 1-2 points.
#5 Effective intercooler surface area should be about 12 square inches for every 5-6 psi anything less no intercooler is needed and more intercooler space raises turbo lag.
Old 05-04-2006, 11:31 PM   #7 (permalink)
Car: Opening soon:
Opps, correction:
Old 05-05-2006, 02:05 PM   #8 (permalink)
JoeMadoo's Avatar
JoeMadoo is on a distinguished road
Send a message via AIM to JoeMadoo Send a message via MSN to JoeMadoo Send a message via Yahoo to JoeMadoo
Nice, those are good facts. So an ideal setup for a turbo in an e30 is E block with I head? I know that lowers the compression a bit.
86 Alpine White 335is M30 Swap <br>My Car Domain
ASE L1 Smog Certified
JoeMadoo is offline   Reply With Quote
Old 05-05-2006, 04:59 PM   #9 (permalink)
Car: Opening soon:
Yes, that would work great. However you'll need the intake manifold as well for the larger intake runners.
Turbo 325es 2.7L??? Anyone done it?? SLEEPYDUB Forced Induction 2 05-02-2006 02:43 PM
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Bmw Track Times dutchbmw Bimmer Talk/Motorsports Talk 2 06-25-2005 08:05 AM
