'85 325e 5-speed manual transmission - BMW Forum - BimmerWerkz.com
Old 09-08-2004, 04:52 PM   #1 (permalink)
xyzzy is an unknown quantity at this point
Thumbs up
I have an '85 325e with a 5-speed manual transmission (Getrag 260) which has a problem with 3rd gear: it won't go into it! It started a while back by occassionally popping out of 3rd, shortly after shifting (up or down) into that gear. I didn't think much of it at the time, figuring that I probably needed to adjust the linkage. But then it started to refuse 3rd, grinding as if I wasn't using the clutch. My only recourse (since I needed the transportation!) was/is to rev it up in 2nd and then jump to 4th (and vice versa on the downshift). This is a half-assed temporary "solution" at best, and it really doesn't cut it when it comes to any city driving!
When I got under the car to check the trans fluid (which normally holds ~1.3qt US) I discoved that I had been losing oil from the rear seal; my trans was low by better than a quart! I've checked the manual (Robert Bentley, Pub.) and realize that it may not be the seal, but rather a blocked transmission vent (which could cause a pressure increase, forcing the oil past the seal). Regardless, the fact remains that refilling the transmission did not resolve the shifting problem.
So, I guess the real question is, has anyone else ever encountered this problem? Have I fried my transmission to the point where it needs replacement, or is it repairable? (While 20 years old and in need of a paint job, with only 165k miles on it the engine is still strong and the body's sound! A new paint job and a repaired/rebuilt transmission are still a hell of a lot cheaper than a new car!)
Any first-hand insight will be greatly appreciated! Thanx... Thom
xyzzy is offline   Reply With Quote
Old 09-08-2004, 06:14 PM   #2 (permalink)
Oxbrain is an unknown quantity at this point
if you double clutch it can you cram it into 3rd? It does sound like something in the linkage from the shifter. I'd say look in the phone book and call your local tranny shop, they could give you the fastest and best answer.
just thinking about all those gears in a tranny makes my head start to hurt.
Oxbrain is offline   Reply With Quote
Old 09-08-2004, 06:17 PM   #3 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
mine did the same thing...sliders in the tranny are probably out...check the shift linkage first but i have a feeling its time to hunt for a rebuilt tranny or a low mileage tranny...mine started as just third gone then went to 1st and 3 and then 1st 2nd and third...lol
Good luck
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 09-15-2004, 03:23 PM   #4 (permalink)
Thanx for the reply Oxbrain, but "no," double-clutching doesn't do it! I'm afraid BMDubya's suggestion might be correct: "time to look for a replacement!" Thanx for the responses... I'll let the forum know what was found after I have it opened-up! ghead
Parting out 1995 E36 318Ti Manual Transmission bacustoms420 OEM Parts 1 01-10-2007 02:08 PM
Manual Transmission Flush Henri 3-Series (E36) 11 10-24-2005 06:24 PM
Parting out 1995 E36 318Ti Manual Transmission bacustoms420 Looking For 0 10-12-2005 12:49 AM
