85 318i slight hint of gas in oil - BMW Forum - BimmerWerkz.com
Old 02-27-2010, 02:15 PM   #1 (permalink)
divot61's Avatar
divot61 is on a distinguished road
ok guys, break it to me easy. is it a head gasket or something else, like rings or valve guides
divot61 is offline   Reply With Quote
Old 02-27-2010, 08:43 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Cool
check your compression on all cylinders... take compression readings for both "wet" and "dry"... and that will tell you where the prob lies.
gas in oil =
stuck or leaking intake valves, (maybe adjusted just a little to tight on the intake valve clearance)
worn rings
Old 02-28-2010, 06:14 PM   #3 (permalink)
divot61's Avatar
ok, ill give that a try and post my results, what is the valve lash settings for that year?
Old 02-28-2010, 09:35 PM   #4 (permalink)
Cool
cold engine:
0.008in/0.20mm COLD for both intake & exhaust.
done 1 cylinder at a time, of course, with each cylinder at TDC at time of adjustment
Old 07-28-2010, 08:05 AM   #5 (permalink)
divot61's Avatar
hey darkhorse, i know its been awhile but i found this old post of mine and im still having trouble with the injector, #3 to be exact, i took the valve cover off and i cannot see any way to adjust the valves, been a mech. for years. are the hyd. ? by chance? its an 85 318i
Old 09-05-2010, 09:04 AM   #6 (permalink)
doitover is on a distinguished road
old thread but I'd guess leaking injector over all the other choices.
doitover is offline   Reply With Quote
My 2003 330i Makes a slight wine when I push on the gas. steelhanna 3-Series (E46, E90) 8 08-14-2008 12:08 AM
Too Much Oil, Wrong Oil, Gas Leak? yammahamma 3-Series (E21, E30) 4 07-26-2005 06:20 PM
318i Gas Mileage deepfat 3-Series (E36) 13 03-30-2005 12:44 AM
92 318i Gas Problem elbow25 3-Series (E36) 3 02-28-2005 05:45 PM
Oil Smells Like Gas - Oil In Sprk. Plg#2 jkh2828 3-Series (E36) 2 01-21-2005 07:18 AM
