79 320I V/S 77 318I - BMW Forum - BimmerWerkz.com
Old 02-23-2004, 11:43 PM   #1 (permalink)
hammerdn is an unknown quantity at this point
I have just recently bought a BMW. I have never before worked on a BMW and I was wandering what parts are interchangable. I have a 77 318I and was thinking of buying a 79 320I if I can use the parts. will the body parts interchange on these years and what about the motor and tranny? they are both 5sp. What is the major diffrece in the 318 and the 320. Thanks
hammerdn is offline   Reply With Quote
Old 02-24-2004, 11:00 AM   #2 (permalink)
will1506 is an unknown quantity at this point
Send a message via ICQ to will1506 Send a message via AIM to will1506 Send a message via MSN to will1506 Send a message via Yahoo to will1506
I'm not sure if there are any major differences. But The Engine I believe are different the 320I probably has a touch more power than the 318i. You have to becareful with the cosmetic parts though. A lot of the time the switches are not compatible (window switches) etc. They fit in perfect fine. But when I tried doing a swap for window switches from a 1984 325E with a 1991 318i. My 30 fuse kept on blowing. And I was wondering why until I found out that the switches are not compatible. But if you can get it for cheap. Than there are a lot of other parts that you can use. Like the fuses are all generic, you might be able to get away with spark plugs and the wires. The RADs and the fans might be the same. Tires, RIMS, speakers, seats. But do double check. But the motor and the tranny are not interchangable. A lot of work would have to be done if you want to do a swap with the engine and the tranny.
will1506 is offline   Reply With Quote
Old 02-26-2004, 07:55 PM   #3 (permalink)
BlitZeD310 is an unknown quantity at this point
Umm not sure if you mean 77 316? Im not sure there was a 77 318. Either way if there was it will most definatly swap with out a problem. They both have the same M10 motor with the same getrag 5sp overdrive tranny. They also have the early CIS system with the K-jet. Most if not all e21 parts 77-83 are interchangeble minus some suspension, and interior parts. But either of the M10's whether it be the 2.0L or the 1.8L are the same, just a little difference with the crank and head/intake system...
<img src='http://e21.tricord.cjb.net/members/cjpix/bim1_050204.jpg' border='0' alt='user posted image' />
BlitZeD310 is offline   Reply With Quote
Old 02-26-2004, 10:50 PM   #4 (permalink)
Official Bimmerwerkz Biscuit Distributer
spiff325is's Avatar
Car: 00 M Coupe
spiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud of
Send a message via AIM to spiff325is
yeah, what he said....
I hate: people who haven't died yet that I hate.
L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc.
2000 BMW M Coupe - Dakar-II - S52
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
spiff325is is offline   Reply With Quote
320i Or 318i M3wannabe2004 3-Series (E36) 12 03-09-2005 01:57 AM
320i V 318i WarNox 3-Series (E36) 23 01-25-2005 02:48 PM
318i vs 318is vs 320i Sabih 3-Series (E36) 18 08-07-2004 12:28 AM
WATs Better a 318i or a 320i ??? nukeall 3-Series (E21, E30) 6 01-13-2004 04:27 PM
