4:10 rear end - BMW Forum - BimmerWerkz.com
Old 01-20-2004, 07:06 PM   #1 (permalink)
BimmerKris's Avatar
BimmerKris is an unknown quantity at this point
Did 4:10 gears ever come stock in the E30's if so how can you tell
<img src='http://bmwforums.penguinstudios.com/BimmerKris/salesig%20copy.jpg' border='0' alt='user posted image' />
<a href='http://www.acantha.ca' target='_blank'>www.acantha.ca</a> 100% thrash your face off metal
BimmerKris is offline   Reply With Quote
Old 01-20-2004, 07:10 PM   #2 (permalink)
They came stock on 325i's with automatic transmission with optional LSD. the 325iX had 4.10:1 LSDs with viscous coupling, the M42 318's had small case 4.10 diffs, and the M3 had a 4.10 LSD which would be a direct swap to a 325i/is.
Old 01-20-2004, 07:14 PM   #3 (permalink)
BimmerKris's Avatar
which one of these would best suit my 86 325e 5 speed i don't know if i have it i do have the limited slip though
Old 01-20-2004, 09:14 PM   #4 (permalink)
4.10:1 on a eta would be way to extreme. 1st gear would be practically useless. the most i would do is 3.73 off an iS, which still may be too short
Old 01-24-2004, 01:10 PM   #5 (permalink)
BimmerKris's Avatar
I got some 17inch 225 45's on the back that will help lenthen the gear will it make that much of a difference
Old 01-24-2004, 02:00 PM   #6 (permalink)
no probably not, also how did you fit those tires in the back? did you have to roll the fenders?
Old 01-24-2004, 02:09 PM   #7 (permalink)
BimmerKris's Avatar
They bearly fit.. had to stiffen up the rear suspention a lot but looks mean. i'll get some pic up once it gets re painted in march.
Looking for a 4:10 rear end crazy91318 3-Series (E21, E30) 5 09-26-2005 09:49 PM
Rear Chamber olmsteade 3-Series (E21, E30) 0 07-03-2005 07:12 PM
E46 Wire Guides (complete) EcianIce Audio and Electronics 2 09-26-2004 07:40 PM
List of common e46 part numbers L337E46 3-Series (E46, E90) 0 06-07-2004 09:19 AM
