| Depending on which engine you have, you might also want to consider heat-shielding your cold-air intake... a must if you have the 2.5L inline 6, because the filter comes out right behind your radiator. (Hot-air intake!) If you do not shield the cone filter from heat, you may actually LOSE horsepower.
__________________ g00ch '88 325i cabrio
<a href='http://www.sicracing.com' target='_blank'><img src='http://members.cox.net/aaron.gochee/images/mycar/p4050007small.jpg' border='0' alt='user posted image' /></a> |
