325iC Rear Wheel Noise - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 09-28-2008, 10:25 AM Thread Starter
jlsr is on a distinguished road
Looking for suggestions on diagnosing a noise in the rear wheels/drive train. As the car increases in speed, there's a growing whining sound in the back. I can't tell if it's related to a particular wheel or not. Kick the car into neutral and coast, the whine is still there. As the speed drops, so does the whine. Doesn't seem to be affected by making turns.
Any ideas? Thanks
jlsr is offline
post #2 of 8 (permalink) Old 09-28-2008, 12:31 PM
PrInG's Avatar
PrInG has a spectacular aura about PrInG has a spectacular aura about
Send a message via AIM to PrInG
wheel bearing ? that would be my best guess.. I don't know much about ur model. But that sounds like a wheel bearing. If that is the case I'd recommend getting it fixed ASAP as you will find that your tires will suffer.
TO HONOR: Get Honor Stay Honor if You Can't Come in Her Come Honor.
"its not banana yellow but its not golden its just that perfect creamy german goodness"
- Bow
PrInG is offline
post #3 of 8 (permalink) Old 09-28-2008, 06:55 PM
OICU812 is on a distinguished road
Check E-brake shoes.
OICU812 is offline
post #4 of 8 (permalink) Old 09-29-2008, 12:28 PM
Help from over the pond
marti5's Avatar
I would go more for the diff, check for leaks and check the oil level in the diff.
whinning is nearly always the Diff, wheel bearings and pads are more of a grinding sound.
marti5 is offline
post #5 of 8 (permalink) Old 10-02-2008, 01:07 PM
Nihilator is an unknown quantity at this point
I thought that, too, and I had the diff and CSB replaced this spring, expecting that would clear it up. It didn't. I now suspect it's a wheel bearing, and I have the same symptoms OP does. A whizzing whine, wheel-speed related, not affected by acceleration, deceleration, braking, engine braking, turning, or anything else.
--Chris
<img src='
Dad's 1992 325iC
Nihilator is offline
post #6 of 8 (permalink) Old 10-02-2008, 03:25 PM
marti5's Avatar
Could be that your discs are worn, the rigde will catch the pad and make this noise or the back plate is catching.
marti5 is offline
post #7 of 8 (permalink) Old 10-03-2008, 12:08 PM
Crazy Fabricatin' Admin
gotKRAUT's Avatar
gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute
definitely sounds like wheel bearing
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast
gotKRAUT is offline
post #8 of 8 (permalink) Old 10-04-2008, 08:59 PM
TRuckee is an unknown quantity at this point
It sounds like you may have a wheel bearing that's failed... I had that happen to a 2000 323i that I once owned. Are you inclined to try jacking the car up and seeing if a wheel seems to be able to be moved (shifted) a bit? I could detect some unnatural movement in the rear wheel that had the failed bearing. Don't drive the car too much. I did and "spun" the bearing and had to replace the drive flange too, about a $80 part.
TRuckee is offline
Grinding noise coming from rear driver-side wheel camnipotent 3-Series (E36) 8 08-21-2007 11:50 PM
325ic, Cut My Rear Window(soft Top) ramkitty 3-Series (E21, E30) 4 07-06-2005 12:24 AM
Rear Road Noise, Noise Gets Lauder As You Go Faste victorgallas 3-Series (E36) 17 01-29-2005 05:05 PM
Strange Rear Wheel Noise? Clint_M 3-Series (E36) 1 10-04-2004 07:37 AM
