325i engine swap - BMW Forum - BimmerWerkz.com
Old 12-09-2003, 07:25 AM   #1 (permalink)
flipsgonetopless's Avatar
Car: 1991 318is
flipsgonetopless is an unknown quantity at this point
Send a message via MSN to flipsgonetopless
Arrow
Hey guys long time no call... Just had a quick question, I have an 89 325i conv. My engine just went to shit, it had a small knocking a year ago and it turned into an ugly loud knocking a month ago, I purchased an engine from a 91 325is for 350.00 which I started swapping over this past weekend. The engine is out and I'm just transfering everything over to the new one... my question is, is this engine going to work with my own ecm? Also I saw on the head of my old one that is has a "2.5" molded into the side of the head and the new one has a "2.5 and a 2.7 right on top of the 2.5, is this gonna make a big difference on my performance of my car? This is only FYI for me, just need to know if I'm going to have to buy a new ecm or not... thanks fellow e30 freaks... have a good one.
flipsgonetopless is offline   Reply With Quote
Old 12-09-2003, 07:41 AM   #2 (permalink)
you should see what the ecu # was on the 91 just to verify. there shouldnt a big power difference unless your last engine was in poor shape for a while
Old 12-09-2003, 07:59 AM   #3 (permalink)
Car: 1991 318is
Well my car is a testimony for BMW engineering, I drove my car about 40 miles on the bad engine at 80 mile per hour on 5 cyl. But the car ran strong it just wounded like me piston was going to puncture through the block at anytime. But I need to get the number to the ecm from that car to compare... thank you sir for the 411.
Old 12-09-2003, 06:45 PM   #4 (permalink)
OreoGaborio's Avatar
OreoGaborio is an unknown quantity at this point
Send a message via AIM to OreoGaborio
it's referred to as ECU, not ECM
and the reason why there's a 2.7 stamped on the block as well is beacuse there was also an m20b27... or a 2.7L m20... ie the ETA engine (the engine in the 325e, 325eS and 325)... they shared the same block, but the eta had a longer stroke
-Pete Gaboriault
<a href='http://www.r3vlimited.com/phpBB2/viewtopic.php?p=2494#2494' target='_blank'>the NEW NEW New England Contact List</a>
<img src='http://mywebpages.comcast.net/digitalwave/petesig.jpg' border='0' alt='user posted image' />
OreoGaborio is offline   Reply With Quote
Old 12-10-2003, 05:09 AM   #5 (permalink)
Car: 1991 318is
Thank you Oreo, sorry for the confusion... . Well I know the difference between the I and E 2.5 and 2.7. But my initial question was will I need to buy the "ECU" from the "is" for my car to run properly. I hace access the the "ECU" to purchase, please help me because I will install the engine this weekend and so that I can have time to buy it.
Old 12-10-2003, 07:52 AM   #6 (permalink)
if you have access to it, deffinately ask the seller what the last 3 digits of the ecu are
Old 12-10-2003, 03:45 PM   #7 (permalink)
if you setarted w/ an m20b25 (325i/325iS/325iX engine) and you're swapping to another m20b25, you shouldn't need a new ECU... but if the ECU you have now is motronic 1.1 & you have access to one that's motronic 1.2, i wouldn't see why you woulnd't swap em.... but i'm not sure if they're a direct plug & play upgrade... your best bet is to get the last three digits like MrM3 said
-Pete Gaboriault
Complete Engine Swap tomsbmw325is 3-Series (E21, E30) 9 04-13-2005 04:59 PM
Engine Swap Need Help mmclaren 3-Series (E36) 15 11-24-2004 02:39 AM
1992 325IS engine + tranny swap danyal711 3-Series (E36) 6 08-20-2004 12:57 PM
engine swap uglydumbguy 3-Series (E36) 5 12-02-2003 04:04 PM
Turbo vs. Engine Swap ryan_george 3-Series (E21, E30) 3 11-22-2003 06:51 PM
