325i engine into 325ix - BMW Forum - BimmerWerkz.com
Old 02-02-2009, 01:04 AM   #1 (permalink)
gman325ix is on a distinguished road
i am looking to put a engine into my 1989 325ix and i was woundering if a engine from a 325i would work. i know they are the same engine ( m20b25 ) but i was woundering if the engine from the 2WD 325i would match up to the AWD trans axle of the 325ix.
gman325ix is offline   Reply With Quote
Old 02-02-2009, 02:46 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
You could try a cross match via part #'s here:
RealOEM.com Online BMW Parts Catalog
Old 02-02-2009, 08:52 PM   #3 (permalink)
that's a hell of a question...a 325i engine into a 325iX application. As a guess I would have to say that yes it would swap out as long as you are not screwing around with the transmission/exhaust/suspension...yes I would guess that the engine itself should be swapable....good luck...let me know on this one as it is an interesting question...as I own a 325iC I know that the iC and iX are six inches longer in body than regular 325i models..however that seems to be from the flywheel back. My guess is that the motors are the same.....same mounts and connections is my, and I cannot stress this too far, GUESS.. but I think I'm right. Keep us posted on this one
silversled is offline   Reply With Quote
Old 02-03-2009, 08:45 AM   #4 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
dont guess...
yes it will work, just swap oil pans and your good to go. the ix has a specific oilpan that allows the transaxle to pass thru it.
Old 02-28-2010, 03:40 AM   #5 (permalink)
Vex
Vex is on a distinguished road
Those aren't swappable.
IX oil pump is very different, it takes oil behind the oil pan and 325I takes oil from front side of the oil pan.
IX oil pump consist oil pressure relief valve, and in 2WD motor it's in block.
Also oil pump fasteners are different.
Vex is offline   Reply With Quote
Old 03-05-2010, 10:48 PM   #6 (permalink)
Vladimir123 is on a distinguished road
TC Electronic G System
Vladimir123 is offline   Reply With Quote
Old 03-10-2010, 02:12 PM   #7 (permalink)
Vex
I just moded 325I RWD block to my IX.
That wasn't so big deal that I expected.
I take pictures for you to realize what have to mode.
But in fact, those blocks AREN'T same and can't swap just right that!
And for example, the oil pump runs different direction in those motors..
Wheels/tires from 88 325ix wont fit on 89 325i Slow325i 3-Series (E21, E30) 2 07-07-2006 07:28 PM
Does 88-91 325ix have same 5 speed transmission like 325i Slow325i 3-Series (E21, E30) 2 07-07-2006 12:31 AM
Engine misfires on 88 325ix , whats wrong Slow325i 3-Series (E21, E30) 1 06-09-2006 09:21 AM
87 325i/is Engine JimmyV 3-Series (E21, E30) 3 02-09-2005 09:36 AM
92' 325i Engine EcianIce 3-Series (E36) 0 09-06-2004 09:44 AM
