325i Catastrophic Wheel Bearing Failure - BMW Forum - BimmerWerkz.com
Old 12-03-2006, 03:22 PM   #1 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Occurred while going about 60mph. A tow was in order there after.
A little damage from what looks like some idiot with a jack.
The entire right side of the car seems to be either frame bent or some type of horrible tow with the hook in the back right...
I cant tell. I think the right rear trailing arm is bent... putting more strain on the bearing which ended up failing.
Does the trailing arm look bent???
Thanks for looking... and opinions are very welcome.
Les
1997 E36 M3 1990 E30 325i
Old 12-03-2006, 03:38 PM   #2 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
True story.
My BMW Blog
Old 12-03-2006, 03:40 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Or maybe the constant velocity joint as I'm being told........
Les
Old 12-03-2006, 03:43 PM   #4 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
Old 12-03-2006, 03:46 PM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
That bend almost looks like it should be there though.
Les
Old 12-03-2006, 05:08 PM   #6 (permalink)
Car: Opening soon:
Catastrophic wheel bearing failure? Considering it's still together it isn't all that bad. If you are local and you need help fixing that let me know. I'll just need to see what got chewed up in there. So long as it's just the bearing and not the hub, no problem. I have a bearing press that'll take care of that. However the ABS sensor may be mangled.
P.S. ldsbeaker, sorry, I still haven't had time to drop off that SI board.
Old 12-03-2006, 06:14 PM   #7 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
I'm in Havelock... and my car is at Adams house... so I'm local... but I have a new half shaft, hub w/ bearing already in there and a new trailing arm coming.
That should take care of her eh?
Les
Old 12-03-2006, 07:07 PM   #8 (permalink)
Car: Opening soon:
Take care of it, yes. But changing everything out is a lot of work.
Old 12-03-2006, 07:27 PM   #9 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Not with Adam to help...
Les
Old 12-03-2006, 07:27 PM   #10 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Yes, yes it is. I find nothing wrong with working on a car for a whole weekend... although pressing the hub/bearing ... I don't have tools for that.
My BMW Blog
Old 12-03-2006, 07:28 PM   #11 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
I wont need those tools... as the parts are coming already put together... ... bearing included.
Les
Old 12-03-2006, 08:58 PM   #12 (permalink)
Car: Opening soon:
Sounds like alot of unnecessary drama and to me. Have fun. If you get stuck, email me.
P.S. Buy a GOOD set of triple square bits and really clean the bolt heads out with a tooth brush, or else you are going to have tons of fun.
Old 12-03-2006, 10:01 PM   #13 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Well... I looked at those bolts today... the 4 that attach the half shaft to the diff... I presume your speaking of those???... If so.. they are rather clean to tell you the truth... no problem.
Thanks,
Les
Old 12-13-2006, 12:04 AM   #14 (permalink)
joshh is an unknown quantity at this point
Time to service that rear end. It's leaking and filthy.
Finally pulled the M50 from the donor car.
joshh is offline   Reply With Quote
Wheel bearing replacement DIRTE30 3-Series (E21, E30) 2 08-11-2006 02:29 PM
Urgent advice needed about buying 2005 318ci bmwdxb 3-Series (E46, E90) 8 07-27-2006 12:43 AM
wheel bearing? bob318 3-Series (E36) 3 02-21-2006 12:15 AM
Rear Wheel Bearing, Replacing victorgallas 3-Series (E36) 0 04-06-2005 06:59 AM
Wheel bearing screwed Turbodefrost 3-Series (E36) 0 09-06-2004 11:19 PM
